Computers & Internet Logo
Anonymous Posted on Dec 31, 2008
Hi i need a help! i am looking to find '' '''''' drivers for targa traveller 1512 for xp edition thank you very much!
  • Anonymous Jan 01, 2009
    thank you very much for the help! you are very helpful and super!! i will introduce you,, to everybody!
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Dec 31, 2008
Anonymous
Expert
Level 2:
Answers
69
Questions
Helped
43506
Points
156
This link should get you to the downloads page, but if not, use the below instructions.
http://www.service.targa.co.uk/ is where you'll need to go, further navigation does not change the address bar, so you'll have to follow step-by-step.
  1. Select "Targa Mobile PCs" under the ModelFinder on the right.
  2. The Targa Traveller 1512 should be the 4th down.
  3. Once on the FAQs page, you should see 3 tabs above the picture of the laptop, Select "Downloads"
  4. The XP package is the first download in the list.
I have a targa 1534 laptop. used it upstairs on the bed and may have blocked the cooling fan. In any case the screen has gone blank with only a blinking curser top left hand side. Help - have I blown it...
you might have overheated and corrupted your graphics card and its driver software make sure the graphics card is securely seated and check the lead that attach motherboard to hard drive these might have overheated and lost connectivity a computer needs to have current and data to travel up to and through every device for it to work properly even the cd/dvd must work in/out even the fan and its lead must work
hope this helps
Hi ,i need a driver (Win/XP) for my pinnacle
try this download this program instal it,scan and update you driver from here http://www.radarsync.com/
TARGA TRAVELLER 1591 TRYING TO
try reading through the following link for assistance. I realize it is quite lengthy but should help you with your issue. http://forums.nvidia.com/lofiversion/index.php?t24169.html
No executable program in graphics card drivers folder
depend on your OS as to how you go about this but basically click "start" the right click on "my computer" select properties. this will get you to system properties..slick the "hardware tab then the "device manager" button.
Find "display adapters" and right click on your current video card and select update driver. tell it no to search the internet then click on the "install from a list or specific location (advanced)" you the should come to a window where you can "browse" to and select the folder where your new driver is located. it will look for the .inf file and install the driver. This is a walk through using XP its gonna differ a bit on Vista but its basically the same thing.
1helpful
2answers
No executable program in video drivers folder
I have a TARGA TRAVELLER 1574 X2 LAPTOP which is about 2-3 years old. I was using it last week, everything was fine. I put it away, but when i came to use the laptop later on, the screen was completely blank. The power button was lit up and everything else was ok, but no power was going into the monitor. Ive tried to see if it had gone into sleep mode, but to no avail. Ive even tried to reboot with a WINDOWS XP disk but nothing. Do you have a solution to my problem?
Hi..
Try this website http://www.service.targa.co.uk/
Hi! again
try to find the correct initiatials from the computer manage and then properties then enter them in the web searh
Good morning
Its on the Targa website in the Service site
TARGA TRAVELLER 1591 TRYING TO DUAL BOOT ITS GOT VISTA I WANT TO INSTALL XP PRO BUT XP CANNOT SEE THE HD IT NEEDS THE DRIVERS. HOW DO I INSTALL THE DRIVERS FOR A SATA DRIVE INTO MY XP INSTALLATION CD
OK I managed to install XP on Targa Traveller on 1591!
With the CD of window XP it is necessary to make F6 for the starting up of the installation and to use a diskette with the pilots(drivers) SATA of NVidia nforce. Naturally the most practical are of incorporated the pilots(drivers) SATA into the CD Windows but I knew how to make;) link for the pilots(drivers) SATA:
Http://garlon.free.fr/Appli/NVidia /
If after the intallation of the pilots(drivers) at the beginning of the copies of file An error of copy of file (cann' t copy spin NVr dll) make Esc (65 files nvidia not copied) and continue the installation up to the restart.
I put out(switched off) the computer, removed the hard disk to put it in an external box usb on another computer I have to copy files dll to System32 or system32 / drivers, file .inf on file windows/inf and file .sys on system 32 or system32 / drivers
I restarted the computer and finished the installation links Pilots(Drivers) xp (I am not sure for Chipset drivers Chipset...you must verify)
http://fred.garlon.free.fr/Appli/Targa
Good luck
Grand Canyon Tech
Grand Canyon Tech
