Question about Toshiba Satellite A75-S211 Notebook
How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
  • Anonymous Feb 16, 2009
    A JHJK
How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
Posted on Jan 10, 2009
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
Sep 22, 2010 | Toshiba Satellite A75-S211: A75-S211 Intel...
How do you replace a keyboard on a Toshiba a75-s211
hi look here.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
please rate.
hope this helps
Feb 02, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
My Toshiba A75 S211 shot off
the issue is likely thermal shutdown (it got to hot) listen to establish whether the fan(s) are working. you will need to take it apart to gain access to the fan area to clean out the dust and dirt.
Mar 24, 2009 | Toshiba Satellite A75-S211 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    It doesn't work on battery
    check the power option in control panel, also remove the battery then insert it again
    Oct 17, 2008 | Toshiba Satellite A75-S211 Notebook
    Trying to find website that I have seen befoe that has instructions on how to open up the A75-S211
    Problem solved. Lap top stripped apart and that little line of dust got cleared out and now the laptop works as if new. Thanks to the website I posted above that shows how to safely dismantle the A75-S211.
    Oct 02, 2008 | Toshiba Satellite A75-S211 Notebook
    Laptop simply stops on starting
    take out the battery, plug in ac only, and try it again
    Mar 23, 2008 | Toshiba Satellite A75-S211 Notebook
    Troubleshooting with Toshiba Satellite A75-S211 Notebook
    try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
    i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
    Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba Satellite A75-S211 Notebook Logo
    351 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
