Question about Dryers
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
  • 180 Answers
Check for correct voltage, if ok probabley start up capacitor on motor or the motor itself
Posted on Jan 01, 2009
  • 76 Answers
It sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
Whirlpool gas dryer Model GGW9200LW0. tumbler will not start everything functions as usual but the motor makes a humming noise and the tumbler will not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
8 year old dryer. drum not spinning to tumble the clothes. checked and the belt is ok? What is the next thing to troubleshoot?
Check that the motor is turning. If not turning, is it humming? If humming, then the problem is likely start winding or centrifugal switch failure. Try lubricating centrifugal switch if stuck. If that does not work, replace motor. Be sure to disconnect dryer before working on it. Centrifugal switch assembly is located in the motor frame on the shaft.
Nov 28, 2010 | Whirlpool Dryers
Whirlpool gas dryer won't spin and there is a deep humming sound with an electrical odor
Sounds like the drive belt has broken and is rubbing against the motor pulley, which causes the smell.
You can order a new one online, or from Sears. Replacement is a matter of gaining access to the inside of the dryer, remove the old belt, and figuring out how to get the new belt around the drum and motor pulley.
Dec 11, 2009 | Whirlpool Dryers
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
