Question about Sony STR-DE485 Receiver
Sony STR DE485 (Audio Video Reciever)
My right audio channel is not outputting any sound. It is not the speaker or cable. Does anyone know what the problem could be and possible ways of repairing it, including easy dismantling instructions. Cheers, Fabrics
  • David Kinnaird May 07, 2007
    I will check it out. Would this resistor be on the main board or the power supply board?
    I was thinking that it would be a switch stuck in the relay which switches the front speakers on. In my experience, relays are usually the first thing to go with hardware. But it is hard to test this without removing the relay.
  • Anonymous Mar 31, 2014
    I have a s-video connection for the monitor output on my str de 935 and a hmdi connection on my tv,do they make a cable for this?
  • 56 Answers
Your problem must be caused by the right channel (rear, front whatever..)side feeding resistor on the power supply.
Posted on May 05, 2007
SOURCE:
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Optical audio
are you sure what your plugging them into on the TV is an output? most of the red white yellow jacks on TV's are inputs not outputs. also on same thing on the receiver make sure its an input not output
Aug 03, 2013 | Sony STR-DE485 Receiver
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Subwoofer has no sound but power light is on. also rca cable is good
run through the settings and see if by mistake you turn the output to the sub off
Nov 07, 2009 | Sony STR-DE485 Receiver
My Sony STR-DE135 reciever has sever distortion on the right channel speakers (A&B) no matter which input is selected. I can not find any obvious fault on the board. Any tips to help me fix it?
It sounds like your receiver may have a damaged output IC. I'm assuming that you've already tried a known good speaker on the right channel but if not, that would be a good idea. Also check and verify that the speaker wire is not damaged and that the terminals at each end are securely fastened.
Good Luck,
BB
May 16, 2009 | Sony STR-DE135 Receiver
Sony STR-DE485 Receiver Logo
300 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
