Question about Stoves Kitchen Ranges
My stove works but my oven does not! We had to cook our Christmas Turkey on the BBQ! Please help. The lights in the oven turn on, all 4 burners of the stove work but no light (on the button) or heat when you turn on the oven. It is a Kenmore that is electric and about 10 years old. Any suggestions would be welcomed. Thanks, Johann
  • 3,037 Answers
Hello daveandjohan
It needs 240 volts to heat the oven, if the clock/timer control isn't sending enough, then you would need a new clock/timer assembly.
Even though, everything else still works and you wouldn't think that this would be the problem, this is the problem, sorry to say, not much else controls the oven. let me know if you have any further questions. good luck on the replacement
bestdarngood
Posted on Dec 31, 2008
    President:
  • 2,110 Answers
If your oven has a pilot light, that could be out. If it is lit, it may be the thermocouple (a sensor that doesn't let the gas flow to the oven if it detects no pilot light lt) may be at fault.
Not hard for someone who is handy to replace.
  • Sibananda Jena
    Sibananda Jena Dec 31, 2008
    or try this
    Sounds like you have an element or both burnt out. Should have a top
    and bottom one inside. Check for any sections that are missing sections
    out of it. Heating elements are around $30 each. If you need to pay
    someone to install them, it might be cheaper to replace stove.
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
How do I fix my stove? None of the radiant elements are working.
Have you confirmed that you do have 220 volts at the range outlet? If you don't, turn your breaker off then on and recheck the voltage with a meter. Any losses of voltage through the breaker indicates you may have a bad breaker. (Do this with the stove unplugged from the stove power receptacle). Next, have you pulled one of the elements off the stove and checked it with an ohm meter to see if you have continuity. No continuity indicates the element circuit is incomplete and the element needs to be replaced (you should have a reading on the ohm meter if the element is good).
Dec 30, 2014 | Samsung Electric Convection Range...
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Jenn-Air JGR8850 Gas Oven doesn't hit the right temperature
this is the oven thermosat of the flame failure device not working , you could be looking at buying new as this wiil not be cheap fix ..............
Jul 31, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oven not heating and oven control lights not working
Check if the oven is in AUTO cook mode. It should be in MANUAL cook mode , check if it has a MANUAL mode button. Sometimes resetting the clock will put it back into MANUAL mode.
Nov 05, 2008 | GE JBP25 Electric Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
