Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Freezer working fine but fridge isn't
LRFD22850ST bottom freezer/fridge
The freezer reaches -11F no problem, but the fridge will only hold around 50F.
If freezer door is open, air flow to the upper fridge part is fine, but when freezer door is closed, air flow stops.
Have tried: defrosting entire unit and vacuuming air intake in back.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
  • robert chavis Sep 16, 2013
    i have the same problem in a bottom freezer model. the ve nt is open and there is no blockage at all..yet it still has little air flow when the freezer door is closed???
LG LRFD22850ST fridge not cooling, but there is a blizzard in freezer. Any ideas??
Fan failed or freezer so chocked up with ice fan can't circulate air into food compartment.
Nov 12, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRFD22850ST FRIDGE NOT COOLING
First make sure your unit's condenser coils are clean. Blow out the dirt and vac up the dirt.
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
BOTTOM FREEZER WORKS GOOD ,BUT TOP REFRIGERATOR PART IS VERY WARM
defrosted around fan between freezer and fridge. works fine now
Mar 03, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
LG will not defrost motor making a noise like ice hitting it
I had this issue as well, techs replaced the control board and problem solved. Mine was done under warranty during the first year, hope yours isn't too expensive.
Dec 29, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Changing panel display from farinheit (sp?) to celcius
Hold the colder button for the fridge and the colder button for the freezer both for about 3 to 4 seconds. It should change to C.
Dec 25, 2007 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
660 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
