LCD TV SOUND BUT NO PICTURE
When turned on channel flashs on for about one second and then goes black, sound is fine,any ideas, could this be a costly repair?
  • carolina602 Feb 24, 2009
    Picture flashes on for 1 second then the screen is black. Sound is fine
  • lenmartin Mar 22, 2009
    I am experiencing my second problem with this Samsung model.
    billn352's fix worked for my Samsung when it would not turn on--NO VIDEO AND NO AUDIO. The fix worked for a week, then I lost the video but RETAINED THE AUDIO. I removed the back--the caps I replaced and the other caps on the power board appear to be fine.
    So my current problem is carolina602's problem and not billn352's problem. Is it a power board problem or a video board problem?
    Scholar:
  • 56 Answers
Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Posted on Jan 01, 2009
Thanks Bill! You fixed my problem! Saved me $400!
Posted on Dec 26, 2009
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
40" Toshiba TV - Flashes on for a half second, then no picture
Sounds like main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Toshiba 40E210U 40 in. LCD TV
There is a picture for about 5-10 seconds then the
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get picture back.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | JVC LT-37X688 37 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Koss KLD2700 LCD TV no picture
http://www.fixya.com/support/t860220-screen_blank
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Televison & Video
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Televison & Video Logo
333 people viewed this question
Top Televison & Video Experts
Electro Med Services...
