Question about Nikon Coolpix 5700 Digital Camera
Unable to download pictures to my computer
I downloaded nikon view 5.1.4 from nikon site. The first time I was able to transfer pictures to the computer. I have a HP pavilion a305w with Windows XP home edition. When I tried to transfer pictures the next time, they would not transfer. When I called up the nikon view 5, and clicked on transfer, I got a message that there was no CF card in the attached camera. I have tried to transfer the pictures several times, but have had no success. I'm I doing something wrong, or do I need to unstall the Nikon View and reinstall. Thanks for your help.
  • ajmiracle Apr 20, 2009
    The Nikon Transfer Program does not start automatically. When I do get it up and running Manually it gives me the option to start transfer, but when I click on the button, nothing happens!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Aug 27, 2012
  • 79 Answers
SOURCE: Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Posted on Aug 29, 2005
  • 3 Answers
SOURCE: Can I transfer photos back to the card after editing the images?
Connect the cam to a pc and turn it on. Discard the box that pops up. Open windows explorer. You'll see Removable Disk listed in the folders pane. Drop all image files you want to transfer to a folder named Nikon under the Removable Disk folder. But the files must be named DSCNxxxx for the camera to understand them.
Posted on Sep 13, 2005
  • 6 Answers
SOURCE: Troubleshooting connection problems to the camera - Windows
Click the "Driver" tab Click the button marked "Reinstall Driver" or "Update Driver"
Posted on Jan 19, 2006
Steve5
  • 423 Answers
SOURCE: Use LCD instead of view finder in Nikon D40
Can't be done. Digital SLR cameras only view through the eyepiece, unless they have a "live view" function, which the D40 does not. The LCD is therefore for viewing an image after it is shot, and setting your menu options.
Posted on Jul 09, 2008
SOURCE: NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Posted on Apr 05, 2009
What replaces pictureproject with the coolpix L10 ? will nikon view NX2 work for coolpix L10 ?
Picture Project was replaced by Nikon Transfer and Nikon ViewNX2. Both of those programs will work perfectly well with the L10. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Once the pictures are on your computer, you can use View NX2 to look at them and do some editing.
Jul 22, 2011 | Nikon COOLPIX L10 Digital Camera
My Nikon P60 won't download pictures. It transfered the first 5 pictures in memory and then stalled. Error message says it can't copy the next picture and it won't copy subsequent pics either. The only...
Try downloading from the memory card. You will have to purchase a card reader, usually less than $20. It will save the batteries, too, since the reader is powered by the computer.
Make sure the batteries have a good charge. The camera powers the download not the pc.
Dec 12, 2010 | Nikon COOLPIX P60 Digital Camera
I have a nikon D70 but have no softwear
You don't really need any software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
There are also plenty of photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
Between them, Nikon Transfer and Nikon View NX will perform thoses functions. You can download them from the manufacturer's web site at http://support.nikontech.com/app/answers/detail/a_id/61
Mar 25, 2010 | Nikon D70s Digital Camera
Unable to transfer pictures from my camers to computer.
go here and download the drivers from here and then it should work if it doesent then email me at dabigbmc10@gmail.com
Oct 05, 2009 | Nikon Cameras
Just get a card reader and insert the smart card from the camera into it. It will show up as a drive on you computer. Go into the DCIM file and your pictures will be in there.
Nov 25, 2008 | Nikon Coolpix S51c Digital Camera
Can't get videos off the camera
here is a easier way to view/transfer your videos/pictures.....
if your running Windows Xp or Vista great.
select your menu button on the back of the camera , then Shooting menu, then Set up, scroll down to Interface, then USB, select mass storage. press menu to exit.
turn your camera on after you connect the USB cable to your computer and camera.
a new hardware wizard should be active, Xp & vista provides the drivers and a one time deal. your camera turns into a removable hard drive or like a jump drive.
you can drag & drop the video files easily into a folder .....
make sure you have the latest Quick Time Player to view the videos.
http://www.apple.com/quicktime/download/
and here is the manual on the Coolpix L10
http://www.nikonusa.com/pdf/manuals/noprint/L11_L10en_noprint.pdf
you can download the free adobe acrobat reader for free also.
http://www.adobe.com/products/acrobat/readstep2.html?promoid=BUIGO
Aug 01, 2008 | Nikon COOLPIX L10 Digital Camera
Hi I have just been iven a nikon 3200 by my father minus the usb cable - I am trying to transfer pics from the onboard memory to my pc. I have now got the usb lead, have connected to the pc...
Hey charliedee,
The program that came with this camera to allow uploading of images to your computer is called Nikon View. Nikon does not provide a free version of this on their website, but you could probably find a free download of Nikon View by searching for it on the web. If all you want to do is transfer your images to your computer and you don't need all the other utilities that come with Nikon View I have provided a link to a download of Nikon Transfer that is free through Nikon, which should allow you to transfer your images to your computer. I hope this helps!
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=61
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Cameras
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Jun 15, 2008 | Nikon COOLPIX S5 Digital Camera
Apr 20, 2008 | Nikon Coolpix 4300 Digital Camera
Problem with my camera recognizing my memory card
Try this download those you can Then delete them off the card. Do the remainder show up then? This may be a lack of computer memory thing.
Aug 06, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
261 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
