Question about NEC Electra Elite DTU 16D-2 Corded Phone
Directory Button need programmed to display caller ID
Do you help to program NEC phone systems?
  • 1 more comment
  • Eric Conrad May 11, 2010
    Press , "3"  (or , "3" on older systems) and read the software level on any idle display telephone. Let me know. Also, what programming do you need?
  • gene dunworth May 21, 2013
    pressed 3 and nothing
    hello
  • 149 Answers
We would need to know the phone system type you are trying to fix. It is the box where all the wiring is, usually a telephone closet or server room. Let us know and we can help.
Posted on Jun 13, 2009
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
Apr 18, 2013 | NEC Electra Professional ETW-16DC-2
Caller id now shows number instead of name (new provider)
This is something you could be walked through with tech support. They would need to know what type of system and what cards are in it, in order to program it. ldtsnj.com
Apr 22, 2009 | NEC Electra Elite 32D-1 Corded Phone
I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Dec 31, 2008 | NEC DTU 8D-2 Corded Phone
Would you be able to help me to program the directory button on our NEC Elite phone system so we could scroll back through caller ID for the last 50 calls?
You can pull the card out hot. The KMM chip is IC6 toward the connector at the back of the card. The other requirement, if you have the KMM chip, is that Caller ID be enabled for your MIFM card. It is done through system programming. You can turn it on by these key sequences. Follow this EXACTLY from a display phone (start idle): <Feature>, #0*8974, press <Line 7> button, press <Line 3> button, press *, 4,01, <Transfer><Speaker>. Test again. One other item, MIFM firmware 5.0 is required for 50 call storage. If firmware level is lower, you will only get 10 call storage. If all the above fails, you will need to call a certified NEC technician to check it out.
Dec 31, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Oct 30, 2008 | NEC DTU 8D-2 Corded Phone
Caller id not working
the directory key is storage for caller id. dtr80 is not the type of system but the type of phone.
The system needs to have other components like a mif card in order to store caller id.
Also if your phone does not ring with incoming outside call than you will not get caller id.
Oct 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
189 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
