I put washer on pause instead it dumps the full load of water without going through wash cycle
This is caused by a faulty control board. The button you referred to is part of the board and the control board manages all aspects of the wash cycle. You will need to replace the control board. Here is a link to the part you need.
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
SOURCE: GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
SOURCE: GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I
thought I might have to unscrew the entire control panel just to
replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer
clip. If you pull out the knob (into the "start" position), you can
use a flathead screwdriver to push the clip out. The knob then will
slide easily off the metal stem. A GE replacement knob costs $9 or
$10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that
engages the dial has eight, flimsy plastic teeth. At any time, four of
these are supposed to engage four little slots in the dial. However,
the way the knob is designed, there will be a lot of wear and tear on
these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
