Question about Legacy Audio American Legacy II LA590 Car Audio Amplifier
Power problem I have a problem trying to get my amp to power up. I have everything connected the right way. I know this cause I am replacing a smaller amp with it. My problem is that the amp will not power up and I dom't know what size fuse I need to put in the amp itself.
Do you actually see a fuse in it? If there is a fuse it should typically say on it what the rating is.
Posted on May 13, 2007
SOURCE:
Tda7293 IC in behringer b215a keeps blowing, whats the cause?
Problem in the part of the power supply that feeds the tweeter amp. Fix the power supply and epoxy the board where it needs to be epoxy. Best of Luck! Serge Lavallee.
Dec 19, 2013 | Behringer Eurolive B212A Speaker
Tried starting my 97' vz800 it was cold say 38 it turned over a few times I heard a click and then everything went out no power what so ever. I looked at every fuse including the 30 amp main fuse and...
A faulty starter could drain the battery but not completely.Sounds much more like a bad earth connection try attaching a jump lead or heavy cable between the negative battery terminal and the engine and try it again.
Nov 10, 2013 | Motorcycles
My Coleman Powermate 2000w inverter gives an error tone when I try to run a 600w space heater. I've tried two different deep cycle batteries...one new, and even tried them in parallel. The connection...
Hi
Assuming there is nothing wrong with the inverter or heater.
You need to check the voltage on the input clamps of the inverter (+ & - connections on the back of the inverter) when going under load, if the voltage is going under 12 volts as it is applying power to the heater there is a connection or volt drop issue.
The inverter is capable of drawing up to 190amps from the battery this can cause damage to the battery.
It is very rare for an inverter of this size to be used on 12 volts.
There are a long list of calculations which I am not going to bore you with, but for this inverter to run on a 12 volt battery system and not cause unesesary damage to the batteries you would need 8 x 120AH deep cycle batteries.
Jan 28, 2011 | Electronics - Others
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
My amp keeps going into protect
do you have the right size ground wire, relative to your power wire? If your ground is smaller when you turn it up there is alot of power it needs an exit and if the wire is too small it travels elsewhere maybe your rca, causing your amp to protect.
Dec 27, 2009 | Nitro BMW-481 Car Audio Amplifier
Power problem amp
Sounds like its going into protect mode-try disconnecting the speakers from the amp entirely and turn the system on if it stays lit up- then ya know its the speakers (one of them at least) thats making your amp shut itself down. If thats the case look into replacing the speaker thats causing the problem.Also make sure that you have sufficient wiring to your amp - at least 8 gauge if you can. check all terminals /power/ground make sure everythings connected tight and not grounding out anywhere
Mar 29, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Hifonics Brutus BXi 1208d Amplifier
Possibly you need to return the amp and get a new one cause that could mean an internal problem and its deffective, you could try replacing the fuses or try changing the ground wire, this problem is very unusual
Sep 13, 2008 | Hifonics Car Audio & Video
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Aug 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
Amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Nov 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Legacy Audio American Legacy II LA590 Car Audio Amplifier Logo
151 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
