Question about Hotpoint VLXR1020A Top Load Washer
Everything but aggitation
The whole cycle works except it won't aggitate the clothes. It spins during the rinse cycle just fine and shakes like it is trying to agitate the clothes but it ends up soaking the whole time it should be agitating and then drains and spins.
SOURCE: Washing Machine will not agitate
coupler
Posted on Dec 19, 2007
how to take off agitator
Posted on Feb 10, 2008
  • 1073 Answers
SOURCE: MAYTAG TOP LOAD WASHER MODEL
remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Posted on Apr 12, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
Posted on May 15, 2008
  • 12 Answers
SOURCE: not agitating or spinning
Crokjcc: If your washer fills up and pumps waterout properly, but doesn't spin, it is most likely the "Motor Coupler". This is a plastic and rubber piece that links the motor to the transmission. It is inexpensive to replace, and a fairly easy repair.
A google for "Maytag motor coupler" might get you some more verbose instructions, but here goes.
First, unplug the washer. Getting electrocuted, while entertaining for others, is unpleasant.
Next, Remove the washer cabinet by removing the two screws at the base of the control panel, tilting the control panel up, and unclipping the 2 bronze-gold-looking spring clips. The metal cabinet should be free to pivot towards you and be moved out of the way.
Near the floor at the front of the washer you will see the motor. It is in a "sandwich" with the motor between the transmission and the pump. A number of flat spring clips and a bolt or two hold the sandwich together. Snap the clips off and remove the pump. Another couple of snaps and you should be able to slide the motor out. The broken triangle thing is part of the coupler, and the rest is still stuck on the front shaft of the transmission.
Here is a picture of a coupler. This may or may not be the one for your model, I didn't check.
J_carey, this is probably NOT your issue, since this_usually_ causes it not to spin or agitate. Yours sounds more expensive to fix.. :(
-ellie
Posted on Jun 26, 2008
My Amana washer doesn't aggitate during wash cycle
What is the model number of your unit?
Nov 30, 2012 | Washing Machines
Just purchased used a Kenmore stacked washer/dryer: tub spins during aggitation cycle. So my clothes are spinning around in water but not being aggitated. Now Im aggitated!! Grr!! How much will it cost...
Sounds like the plastic spacer between the transmission and the tub has broke. Part is no more than 5-10 bucks. Labor, not sure. Did you buy the warranty....I think you still have time to buy it if it's new... But I think Kenmore may guarantee for 30 days but you may want to call where you bought it from new.
Dec 14, 2017 | Kenmore Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Hotpoint VLXR1020A Top Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
