Question about Magic Chef CMV1000B Microwave Oven
Control Panel of Maytag Microwave CMV 1000B doesn't work
The buttons on my Maytag Microwave Oven are not working properly. It is a flat panel ( the buttons are not raised buttons) and when you hit the buttons to enter the time or start the microwave you have to hit each one 10 or 15 times until you hit it just right. Is it possible to repair this problem, or to simply replace the control panel??
  • Anonymous Mar 15, 2014
    Installed new magnetron to microwave. All electrics are running but now the start button will not work
  • Magic Chef Master
  • 9,086 Answers
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 01, 2009
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Half of the buttons quite working. Everything else is fine. Any ideas how to get the buttons working again?
moz-screenshot.pngA new control panel will fix that. Spares can be obtained from the manufacturers agent, see web sit, or ebay, espares etc.
Jan 04, 2011 | Maytag MMV4205 Microwave Oven
Maytag mmv5000bdw Touch panel works intermittently The panel will not respond to the touch. Work around include: 1. closing the microwave door hard and trying again. 2. unplugging the microwave and trying...
If nothing works, it sounds like you didn't get the cable inserted properly. It should fit into a connector which carries signals to the microwave's control components. These connectors usually pullup, you insert the cable, and push the connector back down.
Oct 14, 2009 | Maytag MMV5000 Microwave Oven
Microwave CMV 1000B
yes but you will have to take door apart!
Dec 09, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag Microwave MMV5207AAQ control problem.
Nuke, Sounds like your touch pad is going south. Why dont you kill the power, drop the control assy. and unplug the ribbon of the control panel to the board. Take an eraser and clean the ends of the ribbon where it connects to the board. Put it back in and see if that made a difference. If not I would suspect it's the touch panel. The part number I have for this is 53001508. Good luck.
May 15, 2006 | Maytag MMV5165 Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
838 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
