Question about Rival 1500 Watt Radiant Heater
Need part need a low, high, medium, switch for a Rival,BASEBOARD HEATER. The MODEL# that I took off the heater is BB-40A, now i called a division of Jarden Consumer Solutions and they said that was not the model number. The data plate on back of the heater says it is! So what i'm going to do is give you all the imformation that is on the datd plate. RIVAL,BASEBOARD HEATER 9609 120V, 60HZ, 1500W, 12.5AMPS PREFIX #96-BB1-025035 81D1 That is all on the data plate, there is no part number on the switch at all. Thank you for your time. james perry 4M YOUTH SERVICES 512-446-3930 WORK PHONE 936-581-0857 CELL
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Rival crockpot knob
Try one of the following sellers:
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Posted on Nov 09, 2008
SOURCE: Rival Crock Pot . The
I used a Ampmeter and tried all positions to see Current wich told the heat settings
Posted on Dec 23, 2008
SOURCE: Can't go straight to warm setting
Hi, Guys,
I discovered this solution by accident. To get my crock pot to go to the "Warm" setting directly, I begin by pressing and holding the "Cook Time" button. Then, with the cook time button held down, press and release the "Off" button, holding it down for a second or so and then releasing it. Finally, lift your finger off the "Cook Time" button. Presto! The unit will be set on "Warm." So the key to this is to press and release the "Off" button WHILE the "Cook Time" button is being held down. Might take a couple tries before you get it, but then you'll see that it works every time.
Posted on Jan 24, 2009
Deneenie
  • 73 Answers
SOURCE: Need replacement lid for Rival crock pot
OKAY...I'll help you figure this out
Rival doesn't even acknowledge that model number (3154) in their replacement parts. Makes me think we either have the wrong model # or the wrong manufacturer OR more likely we are missing a few of the prefix letters to the model number.
Please double check and make sure you are looking in the right place for it...here's a pic on Rival's website on where to look on the crockpot: http://www.crock-pot.com/CustomerService.aspx?id=rpt
If you are certain it's a Rival and the number is "3154" then call their customer support # at 1-800-323-9519.
If you discover the model number does have a few prefix letters, be sure to enter that on their search page (which is the same link I posted above.)
Not sure what the replacement part will cost but for $35 you can get a used 3154 with lid on ebay: here (that kinda proves there is such a model - so you may have to call Rival at the number listed above.
If this solves it for ya, please let me know by rating this answer. If not let me know. :-)
Posted on Mar 29, 2009
  • 5 Answers
Try the hardware store. Look at the dimmer knobs.
Posted on Dec 19, 2009
Repairing rival titan space heater
Albert, I have serious doubts that you'll find a suitable switch for your needs on this type of a unit. They just aren't available, unless you can walk into a hardware store and know just what you want. Otherwise, these things are made in China for the most part, and when they ship them over here, they don't ship replacement parts for them...
Dec 12, 2013 | Heating & Cooling
Need to replace off switch
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future. need-replace-off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg
Mar 12, 2013 | Honeywell HZ514 Baseboard Heater
Need a thermostat for model no hz-514
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
BASEBOARD HEATER NOISE
HOW ABOUT THE MARTIN HEATERS I LIKE THEM BUT DONT USE THEM THAT HIGH
Dec 04, 2008 | Fahrenheat Electric Convector Baseboard...
220 POWER TO BASEBOARD HEATER
copy and paste this link into your browser and it will help you. http://www.qmarkmeh.com/Develop/prod_pdf/2500wiring.pdf
Dec 03, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat plf2004
I can help you with this if you still need it.
Oct 16, 2008 | Fahrenheat Electric Convector Baseboard...
Thermostat
Thermostat for what, a furnace with blower, an induction heater, baseboard heater, describe the thermostat, what it is for, how it is wired, and we can figure something out. Write to me at wbwill@sbcglobal.net or at allexperts.com, Will is my real name and wbwill is used for both help sites, the email is my home email
Oct 04, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat baseboard heater knobs
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Jan 10, 2008 | Fahrenheat Electric Convector Baseboard...
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
62 people viewed this question
Top Rival Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
Are you a Rival Heating and Cooling Expert? Answer questions, earn points and help others
