Question about ASUS Eee 900 Notebook
My asus eee pc 900 wont work
Saye file is corrupt windows root system 32,hal.dll
  • helen_doodso Dec 31, 2008
    it says could not read from the selected boot **** check boot path and disk hardware if only i knew how i would
    Genius:
  • 1,913 Answers
Open the cpu cover then refix RAM then checl if problem still remains
then u have to reinstall reapir win xp
Posted on Dec 31, 2008
  • kishor khatri
    kishor khatri Jan 01, 2009
    ypur hrddisk is not deteted in bis
    check in bios setings.
    when u power up press "del or F2 to enter in bios.
    tehn disable sata .
Reinstall windows root system 32 hal.dll
Do a start up repair.
Insert your Windows Operating System disc in the DVD. Reboot your computer and press any key when you see the phrase "Press Any Key to Boot in CD".
Select the start up repair and it should work after the loading process.
I hope this helps.
Carlo
Jan 23, 2013 | Dell Inspiron Computers & Internet
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
My PC wont to start .its says to reinstall windows root system 32 hall.dll
go here to download it on another computer>> http://www.dll-files.com/dllindex/dll-files.shtml?hal
unzip the file onto a USB zip drive than go plug that into your computer and install it. should be pretty simple if it doesn't work try going here and reading up for other possible solutions >> http://social.microsoft.com/forums/en-US/tabspace/thread/b82154ee-6dfd-4ed6-8450-cb22cce444f5
Nov 14, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Nov 09, 2010 | Acer Aspire 4720 Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Windows could not start because the following file is missing or corrupt. windows root system 32 hal dll pls re install a copy of the...
Yes the hal.dll is one of the files it needs to boot up, It gets all of the hardware together..I own and ASUS and they pretty good about sending disk. Pull the disk out that came with the system. Just put it your CD and then go into Windows Explorer and look for that file. Its probably under i386 folder or Win32 folder. Once you find it then just drag it over to the c: drive and you are ready..I didn't get a cd player in mine, so you probably didn't either. I ended up buying one from Best Buy, it works really good, it's an HP.But anyway if you can copy that file over to the C: drive of your computer then you will be ok...it didn't way anything else did it> Let me know how it turn out..
Mar 25, 2009 | ASUS Computers & Internet
Can't start up Windows says I need to reinstall
That file can be found on the XP installation CD.
You will need to boot up on that CD and select recovery console. Try this:
http://pcsupport.about.com/od/fixtheproblem/ht/restorehaldll.htm
You may also be able to boot up to Safe Mode Command Prompt and run system restore:
    1. Restart your system
    2. When the system first boots, type F8 to bring up the boot menu
    3. Select the Safe Mode with Command Prompt option
    4. Log-on as administrator if needed
    5. At your command prompt type %systemroot%\system32\restore\rstrui.exe
    6. Hit Enter
    6. This will open the system restore wizard
Mar 14, 2009 | ASUS Eee PC 701 Notebook
Windows wont start up says needs system 32 hal.dll.
You should be able to do a repair as long as you have the windows installation disk.
You also might be able to take the computer back in time if it will boot to safe mode (or last good boot). Start tapping on F8 after you turn it on to get to the boot preference screen, then select Safe Mode.
Mar 14, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee 900 Notebook Logo
474 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
