Question about Canon PIXMA MP130 All-In-One InkJet Printer
Waste ink absorber almost full,see manual.
Problem does not appear in manual. Wondering how to
fix it.
  • 1,031 Answers
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
hope this helps pls appreciate by rating as fixyaa
Posted on Jan 05, 2009
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
Dec 22, 2009 | Canon Office Equipment & Supplies
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
131 people viewed this question
old marine
old marine
