Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
A noise coming from the motor when I`m ready to vaccum
I have a hoover savvy model 7300.The problem is that when the vaccum is upright sound ok,but when I laid down the vaccum cleaner to start vaccuming and a loud sound coming from the motor.I open it to see, thats why I know.The vaccum cleaner is practicaly new I hardly use it please help.
  • 281 Answers
If it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Posted on Apr 29, 2009
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
In Carpet mode brushes are not spinning.
Have you checked to see if it has a belt that drives the brush roller? If it has one it could have come off or broken. Also could be the control switch.
Feb 19, 2010 | Hoover U8135-900 / U8153-900 Savvy Turbo...
On my Hoover Savvy U8174-900 on carpet setting, the brush spins when I pull the vacuum towards me, but stops when I push it forward. Belt is tight and fine.
Hoover savvys have two very common problems that cause this. The first and most obvious is the belt that you checked already. Many times the belt is tight but those particular belts have teeth and should you lose any teeth on the brushroller OR the belt it can cause this.
The other problem this is a symptom of is a bad switch in the handle. It sounds odd but the switch assy in these machines controls 2 motors, one that causes vacuum another that causes the belt to turn! Often time that switch assembly is bad and the smaller motor that drives the belt does not run when the handle is in a certain position. This causes your brush to stop but since the louder bigger vaccum motor is still operating you never hear the small one quit. I would run this again and listen for a difference in sound. In this case you will buy a replacement circut board that is installed in the handle (i usually replace the entire handle assy, the small extra cost is worth the dependability as nobody can seem to determine for sure what makes them go bad)
You can get the parts from any hoover service center, use their dealer locator to find the nearest one. Be sure to take the old parts in and compare when buying new, hoover makes running changes to their product so 2 machines with the same model number can be different.
Aside from a stray bad or pinched wire you're more than surely dealing with one of those two items. I'd focus on the first paragraph as that is by far most common and least expensive.
Best of Luck!!
Jun 09, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Part terminology and replacement help
call tti floorcare 1800-321-1134. have your model number and the plant number ready you will need it
Apr 18, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vacuum cleaner has gotten too loud
take the top off the vacuum and you will see 2 straps one on each side of the motor,take the straps off and remove the base from the upright.the motor housing will be at the bottom of the upright.you will see some screws on the front of the housing and on the back.take those out and the motor housing will come apart.you will be at the fan and the motor itself.theres probably something caught in the fan.
Jul 05, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
164 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
