Question about Canon ZR70MC Mini DV Digital Camcorder
Canon ZR 600 tape won't load
Each time I place the tape in the recorder and push it closed, it sounds like it is spinning the tape up but it will not drop down into the loaded position. The tape pops out and I also get an alarm beep. ???
    Problem Solver:
  • 12 Answers
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Posted on Jan 01, 2009
Samsung VP-D361 Mini DV Digital Camcorder - have not used for a year and now it will not close the tape compartment. I have tried several tapes but when you push the tape in and push down the edge to close...
will it close with out a tape in. if its not doing it with the tape in there is a motor that pulls down something cannot remember its name. so when the deck goes in it can lock in place and hit the switch. if the switch has been damaged it will just eject the deck again. has one swith to say tape in and other switch is for table loaded. sounds like the loaded one is at fault. happens if you leave a tape in for a long time and not been used.
Sep 30, 2013 | Samsung VP-D361 Mini DV Digital Camcorder
I go to record and it looks like it is recording. But when I play back nothing is there. It is doing this on all of my tapes.Tried viewingan old tape but when played back nothing is there,
You could try slaving the camera out to an external screen if you have the cables, you should find a RCA output socket on the camera marked video out (commonly known as a phono)normally yellow also a couple of audio out sockets one red and one white.
If you plug the yellow one into an external monitor you will see if it's the camera LCD screen that faulty.
Also check the iris is not turned down when playing back or recording this can happen if the camera is set to manual.
Set the camera to automatic and try again.
It sounds to me that the iris is closed, if the head drum is spinning you should get something even if it's random signal noise denoting clogged heads anyway the camera would flash up a clogged head icon so first as check the iris.
Sep 13, 2010 | Canon ZR-950 Mini DV Camcorder
My playback video jumps after recording on tape also audio lever rises and fall i does not have this problem when record on the memory card i have a canon Zr camcorder
I have seen this problem many times, the recorder unit needs to be replaced, either something in the tape path has become out of alignment or dirty like a capstan motor or gears or the video head assy is defective. I hope this helps.
Sep 04, 2010 | Canon ZR200 Mini DV Digital Camcorder
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
Canon zr 100 Will not load tape and shut door.
I had the same problem, I see many reports of banging or thumping the tape door side of the camera, I shudder to think the damage that may possibly do but I tried it, No success.
So I had to find a better way to fix the condition. This is what I came up with.
Turn the camera on
With power on take out the battery
Turn camera on/off switch to off.
Reinstall the battery and turn camera on.
I had to do this a few times, the camera is working and still working today.
The answer, maybe a way to reset the cpu or controller in the camera, or jolt an electronic item in the camera......
Dec 27, 2009 | Canon ZR100 Mini DV Digital Camcorder
Canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Dec 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Feb 11, 2008 | Canon ZR300 Mini DV Digital Camcorder
It won't record anything properly,and is making a wierd sound.
Maybe something is loose. Maybe you can try the "Fonzie Fix" below which is actually for problems with the tape compartment not closing all the way when a tape is inserted. I know it sounds silly but it's worth a try.
ericemartin
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
Feb 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
Please help me fix my camcorder
the record button is no good it happens on your model and the zr 500 and 600 as well needs to go to canon.
Nov 15, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder Logo
291 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
