Question about Kitchen Ranges
Need repair manual for Viking stove/oven model VGIC3054BSS to relplace the oven ignitors
  • theobld Jan 30, 2009
    The dealer I bought my range from is no longer in business. Another local dealer won't service my Viking because I didn't buy it from them.. I'm stuck because my broiler won't work.
Turning on one burner ignites other igniters--how to fix the problem?
Posted on Jul 21, 2010
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
Viking range repair manual
My Viking stove ignitors do not spark. I hear the click but get no spark.
David
May 22, 2012 | Viking Kitchen Ranges
Calibrate oven
i couldn't find your model on the sears site,every viking stove i've worked on had two ignitors,if one of the ignitors isn't working correctly could cause heat changes in the oven.if you pull out the racks,then remove the side rack holders,lift up the floor so you can see the ignitors,start the oven,as soon as the ignitors start to glow time them,if they don't ignite the flame within 40 seconds the ignitor is bad.if this is the problem you don't have to calibrate the oven.also if the ignitor or both are bad check the burner tube to see if there's a hole in it.my friend john had trouble with his oven,i went over,had to change out both ignitors and both burner tubes,the ignitors weren't working correctly and burnt a hole through the tube.so check the ignitors first,if you want to calibrate it look at your manual and it should tell you how to do it,or oull off the thermostat knob,look on the back there might be screws there to calibrate it or if there's a hole in the shaft in the shaft that you pulled the knob off of you might need a small screw driver to stick in there,turn it slowly and not to much to the right to increase the temp.hope this helps but start with the ignitors,they are usually the problem.
Dec 18, 2011 | Viking 30" Dual-Fuel Range, VDSC3054B...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Kitchen Ranges Logo
416 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
