Question about RCA RCD123 Cassette/CD Boombox
Radio not working properly
So I was listening to the radio the other day no problem, but then suddenly all of the higher frequencies including the station I was listening to only submit a high-pitched annoying squeal rather than whatever is supposed to be on the station. Any solutions or ideas as to what could have happened or is it time I resign myself to having to get a new radio?
  • 1694 Answers
SOURCE: High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Posted on Oct 25, 2007
SOURCE: An Annoying High Pitch Sound
I have the same problem. Mine seems to deal with the brightness of the screen. I turned down the brightness and it got better. It still makes the noise and I am going to take it in to see if it can be fixed. I just don't want to do with out my TV - Isn't that horrible.
Posted on Feb 04, 2008
ladywinn
  • 5138 Answers
SOURCE: RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Posted on Feb 20, 2009
FLASH O Ride
SOURCE: Help
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Posted on Mar 15, 2009
  • 4234 Answers
SOURCE: RCA VCR makes high pitched whining noise when it's on...
The power supply is starting to fail. There are a number of capacitors in the power supply that need to be replaced. A local repair shop should be able to fix this easily. Figure on $10 max for parts.
Dan
Posted on May 05, 2009
Hello I have a RadioShack police scanner with frequencies on it I have had it for 5 years noe all of a sudden I ain't receiving any action and my squelch
The police and or fire department may have gone digital. an analog scanner will not pick that up. Often departments will switch their frequencies so the "bad guys" cannot listen in. They forget many of us "good guys" listen and can aid them.
Does the squelch make noise if you turn it all the way to open? Then you know the scanner is working.
Jan 31, 2018 | Radio Communications
How can I get my car radio unstuck from one station?
Try disconnecting the negative ground (-) cable from the battery. That will disconnect power to everything including your radio. It might reset it self when you restore power by reconnect the negative ground cable to the battery.
May 19, 2014 | Pioneer Deh-4100 Single Din Cd Player...
It used to work fine, but one day i was driving down the road and the incoming signal that i was listening to suddenly started to go away and then all i heard was engine noise, and no incoming...
sounds like a noise filtering issue, could be caused by the alternator. if it works fine with the engine off then the problem is going to be the alternator. It can also be a bad earth on the radio/antenna
Oct 26, 2013 | Cobra 29 LTD CB Radio
Slightly off frequency is it possible to correct
I assume it is digital tuning?
If it is digital tuning the answer is no.
Sometimes reception is better when you purposely mis-tune by one digit lower or higher than the stations call numbers.
If it is under warranty, try exchanging it or just listen to and compare another one or more of the same model to hear if they are all slightly off frequency.
Aug 03, 2013 | Eton E100 SW/FM/AM Radio
How to overcome encryption on police frequencies on my PRO 96 SCANNER. Stumped.
Law enforcement agencies employ a number of high-level encryption systems, including DES, to prevent eavesdropping on their radio communications. In addition, some EDACS trunking systems have a ProVoice option that encrypts communications to and from specific users. Sorry, but you will NOT "overcome" these encryption systems. Keys for the systems are updated regularly, so even if you "found" a radio from the system you would not be able to listen in for more than a day or so.
Bill B
Jul 06, 2010 | Radio Shack Pro-96 Scanner
I have this scanner and it will scan but it wont pick nothin up
A couple of things could be involved in your problem. You need to be listening to the frequencies that are being used in your area, but most of them will not be transmitting all of the time. Something you can try is if you live maybe about 10-20 miles from an airport and your scanner picks up aircraft frequencies you can look up the airport and find the automated beacon frequency and tune that in. The automated beacon should be transmitting 24/7 the weather conditions of the airport.
Another thing to check is weather you have the correct antenna attached to your scanner and that it is connected properly, the circuits in your scanner may need that antenna to be connected for the circuit to function properly.
If you are using the scanner to listen to your local Fire Dispatch there can be days when there isn't anything happening.
Another problem could be that your local Dispatch has moved over to a new Digital System and your scanner isn't equipped to recieve that System.
Apr 16, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
Need Scanner Frequencies & Codes
Hello there:
here is a whole list of links that will get you what you need ok
I hope that this is very helpfull for you
Best regards michael
  1. Police Scanner Frequencies & Scanner Frequency Resources Police scanner frequency page where you can find scanner frequency resources from across the net U.S. including free and commercial databases and lsitings.www.police-scanner.info/police-scanner-frequencies.htm - Cached
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff! ... police scanners; general police scanner info, police scanner frequencies, live ... 10/03/09 - Police Scanner Frequency Resources (3 New Resources Added! ...www.police-scanner.info/index.htm
  3. General Radio Scanner Frequencies General Scanner Frequencies in subjects including police, fire, aviation, ... Until the day internet becomes free to all, that is something that just cannot be ...www.angelfire.com/wi/scanner/frequency.html - Cached
  4. The Nation's Oldest and Largest Scanner-Only Dealer Frequencies ... name and password for free (although donations are welcome) and ... Copyright © Scanner Master Police Scanners Corporation. All Rights Reserved. ...www.scannermaster.com/Frequencies_s/121.htm - Cached
  5. Scanner Frequencies * Scanner Resources Free Spies Online E-mail. Greetings by Spies Online. Library Articles. Link To Us ... will find police frequencies, general frequencies, scanner radio information and ...www.spiesonline.net/scanner-resources.shtml - Cached
  6. Scanner frequencies, police, fire, NASCAR, airport, Ham radio. Scanner frequency Spectrum database, including police, fire, rescue, racing ... Free US Amateur Radio Call Sign: Home. Scanner. Frequencies. Amateur. Radio. Mass Media ...www.nationalradiodata.com/help-frequencies-frameset.html - Cached
  7. free police scanner frequencies ? washington idaho montanawashington idaho montanaanswers.yahoo.com/question/index?qid=20081023025353AAVGPXU
Nov 09, 2009 | Uniden BC92XLT Handheld Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
Opel Astra G 2002 Radio Set from Japan to Middle east
simply your scanner range is from 77 to 90 mhz. you can not listen to any higher frequencies than that.
Nov 03, 2008 | Radio Communications
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
RCA RCD123 Cassette/CD Boombox Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
