Question about Hughes SDHBH DirecTV DTV Receiver
Hughes SD-HBH Satellite Multiswitch Compatability
Just wondering if a Hughes SD-HBH Satellite receiver will support a DiSEqC Tone burst multiswitch
  • 68 Answers
DiSEqC Tone burst multiswitch are not compatible with directv equip
Posted on Jan 07, 2009
Turn signals dont work.but the hazards wirk.on a 04 aztek
the Hazards and blinkers are usually on different circuits. gotta start at the basics work your way through the system. Check your fuse panel, might as well check all your fuses and replace all blown fuses. if you don't find a blown fuse then I would check the bulbs, if they are the same bulds as the Hazards then you know there good. then I would check for power at the Multiswitch ,the multiswitch is the blinker, cruise control, wiper switch usually on the left side of the steering wheel. if you have power at the switch then replace the multiswitch.
Jul 24, 2014 | Cars & Trucks
My hughes satelite box SD-HBH won't power up
There could be a blown internal fuse or possibly power supply failure.
Jul 15, 2014 | Hughes SDHBH DirecTV DTV Receiver
Need 5 digit code for Hughes SD-HBH reciever
02874,02891,02862,02881. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts
Dec 01, 2013 | Directv Used Original RC16 Remote Control
Satellite stations
Make sure the satellite receiver is properly connected to the television and that you are on the right input. Then make sure that the satellite receiver is properly connected to the cable outlet (common problem; people get the co-axial hook ups on the box mixed up).
If you are still not getting any signal, see if you can find the signal quality or signal reading in the main menu. Make sure that you have a signal at least over 80% (a few 0's on individual transponders are fine). IF you are getting some of your transponders, it's probably an issue with a connection, the dish, or the multiswitch. If you are not getting any signal at all, the cable is probably not connected to the system.
Sometimes, satellite receivers do go bad (just like any other electronic). If you know that the cable is good and that it's connected to the system and you try to hook up another receiver to the cable and that one works, then you can conclude that the receiver in question is faulty.
Feb 07, 2010 | X2Gen MV32T4 32 in. LCD Television
TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Apr 23, 2009 | RCA DISH Network(r) 311 Satellite System
Pixelating & freezing of picture
Hi, Pixelating and freezing are symptoms of loss of signal. You need to check all of your connections. Check for water in any connection. Check your satellite signal strength on each satellite and if low or they are all not there you could have a bad LNB but you need to check the LNBs and the multiswitch for poor or bad connections. Also check for any obstructions in the dish view to the sky or for anything that may not have been tightened down on the dish. Snow and ice builtup will cause this problem as well. Good Luck! Let me know what you find.
Feb 03, 2009 | Hughes Televison & Video
Hughes direct tv receiver (director pack)
get new ones i just had 2 boxes replaced 1 was sd-hbh and the other was a hi-def box both were fried cause the nit wit that set up the system didn't ground the dish and we got a lightning strike that fried them.... i would call direct tv or whoever your sat provider is because mine were replaced for free with 2 brand new boxes.... and you should check to see if your dish is grounded it will usually be grounded to a water pipe somewhere in the area of where your multi-switch is located
Jul 22, 2008 | Hughes SDHBH DirecTV DTV Receiver
2 dtv boxes one Satellite
you need to install a multiswitch so you can run more than 2 coax cables from your dish
Jun 24, 2008 | Directv (DWO2-10024)
Lost locals thru multiswitch
Do you have at least a 2-channel LNB on your system?...accordianman
Oct 15, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Hughes SDHBH DirecTV DTV Receiver Logo
232 people viewed this question
Top Hughes Televison & Video Experts
jason
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
