Question about Dell Dimension 8250 PC Desktop
Removing cover from Dell Dimension 8250
How do I remove the cover, I see the release tab on the top near the back which loosens the back, I don't know if the front cover snaps off or
what. I don't want to force something & break it.
    Sergeant:
  • 207 Answers
Stabalize163,
Dimension desktops usually have a hinged case. With an oval shaped buttton on the top AND bottom. Push both of these buttons and pivot the side panel open. Take it slowly because its usually quite crowded in there and you don't want to pinch your wires/cables between the drive cage and the chasis or end up ripping them out.
Thanks for choosing Fixya
Dave
Posted on Dec 31, 2008
    Problem Solver:
  • 6 Answers
Here is a diagram to help you:
http://support.dell.com/support/edocs/systems/dim8250/replace.htm#1105908
the front plate doesn't need to come off to open the case.
How do i remove the front cover of my dell computer tower 8250
Not sure if you can pull the front cover off this particular model, but to open the PC:
  1. Make sure the PC is powered off and disconnected from the AC outlet.
  2. If facing the front of the PC, lay it on its right-hand side, so it lies flat.
  3. At the back of the PC at the top left, there is a release button. There should also be a release button on the bottom of the PC near the rear (slightly indented into the bottom). While pressing both of the release buttons, pull the cover upwards and the case will open like a clam.
Jul 18, 2014 | Dell Optiplex GX150 Tower Computer - 1GHz...
Remove hard disc from dimension 3100c
David, this is the Service Manual for the Dell Dimension 3100 Desktop PC,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts.
Click on Harddrive
1) Pull the SATA power cable out of the back of the Harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ Note the L-shaped slot in the connector. Lines up with the L-shaped tab on the back if the Harddrive ]
2) Pull the SATA data cable out of the back of the Harddrive,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
[Top example is a SATA data cable. The bottom example is a SATA connector on the motherboard. Again note the L-shape in the connector.
The SATA power cable connector has 15 contact pins.
The SATA data cable connector has 7 ]
3) Now press the blue tabs (Clips) towards each other.
(Can also be said as -> Towards the middle of the harddrive )
4) Pull up, and out on the harddrive.
If I may ask, why are you removing it?
Post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Dell Dimension 3100 PC Desktop
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
How do i open the front cover on my DELL DIMENSION 4600?
Just check the below manual for more information on the same:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 17, 2010 | Dell Dimension 4600 PC Desktop
I need a diagram of how to get inside my C521 to put in additional memory modules. I have 2 1GB modules that I just purchased from Dell. I don't have a manual with instructions on how to get into the...
Good day sir/maam, you need to open the side cover of the dell PC, now look at the picture below:
Turn the PC off, the encircled part is the memory slot, on its side is the release/locking lever, place the lever in the release (push it on the side) now insert the module vertically with then gently push it down until the lever snaps into lock. Do it with the next module, takes a little practice, if the module is snug and fit. thats it. Power on the PC. if you hear continuos
beeping, power the pc off, remove the modules and do the installation again. Do this several times until the PC response.
Nov 05, 2009 | Dell Dimension C521 PC Desktop
NEED TO KNOW HOW OR WHERE TO ADD THE MEMORY CARDS IN MY DELL DIMENSION E521...HOW DO I OPEN THE TOWER
Hi There,
Should be very straight forward.
You can find full instructions here;
http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/index.htm
(this includes opening the cover!).
This model has 4 DDR2 slots and supports a maximum to 4Gb of RAM.
Regards,
MC
Aug 25, 2009 | Dell Dimension E521 PC Desktop
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Putting in memory
Here's a diagram that shows you how to open the case
http://support.dell.com/support/edocs/systems/dim3100/en/sm/cvrop0.htm#wp1238207
Hope this helps and please rate
Sean
Mar 30, 2009 | Dell Dimension 3100 PC Desktop
Trouble removing case on Dell Dimension 4600c
Try this...
I work on these systems on a weekly basis and they can be very difficult to open. I would make sure that you have already removed the feet from the bottom and turn it so that the heavy side (technically right side up) will be facing the floor. Place the palm of each of your hands on each of the buttons and squeeze the system as hard as you can while holding the system maybe an inch or two off of the floor. The plastic buttons basically cover a metal release tab that is actually part of the frame. All of the clamshell type cases are tough to open because of this. Good luck.
Apr 24, 2008 | Dell Dimension 4600C PC Desktop
Dell Dimension 8250 PC Desktop Logo
1,197 people viewed this question
Alun Cox
