Computers & Internet Logo
Posted on Dec 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant boot I get to the bios page it tells me to press delete I do and nothing happens. I am using a elitegroup NFORCE9M-A with Phenom III core cpu,EAH4830 graphics card
Anonymous
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on Dec 31, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
73585
Points
355
Turn off the pc and reset the bios reset jumper...its near in the CMOS battery...press the power botton in 30 seconds and change the jumper in default...turn on the pc and you can go inside now in the bios setup.
THIS MAINBOARD SUPPORT THIS PROSESSOR Phenom II X4 920 (2.8GHz, 125W, 2MB total dedicated L2 cache, 6MB L3
Motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=943&DetailName=Feature&MenuID=1&LanID=0
Processor Support (CPU Support),
AMD Phenom II X4 model 920, uses .0875 to 1.425 Volts, (DC),
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
That is the average voltage range for the AMD Phenom II X 4 processor.
Look back at the AMD Phenom chart again on Wikipedia, and look especially at the voltage range for the 900e to the 945.
Now look at the ECS CPU Support page again, and you'll see your motherboard supports Phenom II X4 processors from 900e to 945.
Since the 910e and the 925 are supported, I know the technology of the 920 is supported.
The Core architecture and nanometer technology it is based on, is supported.
No BIOS update may be needed.
Yes is the answer.
For additional questions please post in a Comment.
Regards,
joecoolvette
[NOTE*
That processor can use up to 125 watts of power. You need a decent Power Supply.
That processor also gets H-O-T!
Make sure it has a GOOD cooling system, and the computer case inside, and the Power Supply, inside, are kept clean ]
Dear Experts, I have problem in Install MAC OSX iAtkos V-7 on my PC HP DC5850 MT i have install the system and after installation it says installation successful please restart your PC or press the power...
MAC OSX cannot be installed on a pc that uses a AMD Phenom processor and/or new ATI chipsets - the cracked version you try to use will work (badly - very unstable) only with older models of AMD Athlon and nVidia chipset. The BIOS settings have nothing to do with that.
Get a Linux like http://www.mandriva.com/en/downloads/one/ instead
I know that there are issues with OSX on AMD systems. Have you looked over at the OSx86 project page? I would start there if you have not.
http://wiki.osx86project.org/wiki/index.php/Main_Page
2helpful
2answers
Hello there, I have a problem I don't know how to resolve. My motherboard is M4A88T-M USB 2.0 with Phenom II X6 1090T Black Ed. Today, while my pc was in stand by mode there was a power outage but was it...
If your systemwill start in "safe mode" you can try a a'system retstore" back to when it was working.
Let me know if this helps through "add a comment" at end of soloution.
Dave
3answers
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
My pc is pen iii is using window 98, i remove the disc and upgrade it in another pc with xp.i put it (disc) back in my system, but is not booting
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
2answers
ECS 755-A2 won't go past BIOS Screen
do you have the setup cd that came with the board. the drivers probably need to be installed. if so run the disk and install the drivers and it will work.
2answers
Motherboard boot up problem
Try clearing the cmos bios on the board there is a jumper on it
Cant boot I get to the bios promt that tells me to press delete then I do and nothing happens. one of your guys suggested to reset the bios jumper there is no bios jumper on my board that I can see MB is a...
No need to reset your BIOS to enter BIOS editing mode.
You'll need a keyboard that plugs directly into the keyboard port, not a USB keyboard. The USB keyboard does not function until later in the boot process and therefore doesn't send the DEL keypress signals when needed at initial boot-up.
Using a direct-plug keyboard, keep tapping the DEL key while your computer is booting up and it should catch the keypress at the appropriate time and enter BIOS editing mode. This way you don't have to get a single keystroke timed precisely to open the BIOS editor. If the computer starts beeping at you, don't worry about that. It's just telling you that you've filled up the keyboard buffer with DEL keypresses which is the intent.
Hope this helps, and please rate my answer.
Cant install windows on my new dell desktop??
try go to BIOS..upon booting up your (turn ON the computer) immediately press "delete / F2" button then check the booting sequence. Make sure its not in default mode, try to rearrange the sequence by pressing "page up/ page down" button.Make your CD ROM as your first boot sequence next to hard drive..
Goodluck!!!!
Grand Canyon Tech
Grand Canyon Tech
