Question about Samsung CLP-600N Laser Printer
Samsung CLP-600N Fuser Count Reset
I replaced the fuser unit a few months ago, after getting a "Low Heat Error" and being unable to print anything. After replacement, I received the message "Replace Fuser Soon". Now I am getting the message "Replace Fuser." I called Samsung and they told me how to get to a service menu, but I see nothing about resetting page counts or anything like that. The only thing I have found are diagnostic tests. Any help would be appreciated.
  • webmaster951 Dec 31, 2008
    Thanks. I used that diagram when I initially installed the new fuser unit. It still gave me the "Replace fuser soon" message. It has said that ever since I replaced it. Now it says "Replace Fuser." I am assuming there is some way to manually reset the page count, since it didn't do it automatically when I put the new fuser unit in.
    President:
  • 2,110 Answers
I'd second that. First try to clear the error then move on with the troubleshooting.
I had an Hp do the same, according to fixyourownprinter.com it could of been the fuser or controller board. So I went the inexpensive way (it need a service anyway) and replace the fuser, etc in a service kit and it was the controller board. Ya never really know.
Posted on Dec 31, 2008
  • 837 Answers
Try turning it off .. remove the new drum .. turn it back on .. when it errors about the drum .. put the new one back in .. let us know
  • 10,515 Answers
Low Heat error...Cycle Power Samsung ML-2855ND printer
There is a problem with the fuser unit. This unit fuses the toner powder to the paper and if it is not hot enough the toner powder won't bond onto the paper.
Try removing the fuser unit, check the two fuser power spring contacts, and insert it back in the printer. If the error still occurs then you may need a new fuser unit.
You may need to get the printer checked out by a technician.
Mar 19, 2011 | Samsung CLP-600N Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
Engine Fuser Low Heat Error on Samsung CLP-600N? What can I do?
i have samsung laserprinter 1610 problom low heat error ple telme anw
ser
Oct 05, 2009 | Samsung CLP-600N Laser Printer
Error Engine Fuser low heat
possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Sep 28, 2009 | Samsung CLP-600N Laser Printer
Low heat error
the fuser is defective and needs to be replaced.
Jun 11, 2009 | Samsung CLP-600N Laser Printer
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
HI, Yes it definitly sounds like your fuser is not getting to the proper temp. I would call Samsung and have this printer repaired or sent back. If you purchased it recently your warranty should be available. Hope this helps!! Thanks
Dec 04, 2007 | Samsung CLP-600N Laser Printer
THERMO FUSE OR THERMISTOR DIRTY OR BAD
Nov 05, 2007 | Samsung CLP-550N Laser Printer
Samsung CLP-600N Laser Printer Logo
1,034 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
CheckitRight
CheckitRight
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
