Question about LG Washing Machines
LG WM1814CW Error Code "LE"
Need to know what this error means or could possibly mean. I do not have money to repair an expensive problem. Please advise the possibilities of what this error means or could mean. Thank you, John C.
  • john_conhart Dec 31, 2008
    I have read almost every thread that relates to the LG "LE" error issue. I have tons of great suggestions and thank you very much for the added assistance as well! I will advise what works...or hopefully not - what doesn't.
  • 1,543 Answers
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Posted on Dec 31, 2008
What does the F2 Error code Kitchenaid Convection Electric Range mean. I tried unplugging the range for a minute and then plugged it back in w/o any results.
You would need a new control board for this fault code but its very very expensive. It would be advisable to invest the repair money into a new range.
Jan 04, 2018 | KitchenAid Kitchen Ranges
I bought a acura 96 car drives great just smokes bad uses min oil
Blue smoke often means bad rings. Expensive repair. Black smoke could mean bad valves. Also an expensive repair.
Check compression. Your mechanic can do that easily, and should not cost a lot.
Aug 08, 2016 | Acura Cars & Trucks
Why is my affinity dryer not heating and showing error code 56
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Panasonic fault codes
I found this error. The simple possible resolution is to reset the circuit breakers feeding this unit and/or replace possible blown fuses. Other possible problems may be too involved therefore a professional should be hired. Just a warning, this problem could get expensive.
Dec 11, 2013 | Heating & Cooling
I have a Model 3200 Outboard Disk Drive which is my backup drive. It suddenly stopped working. I find 12.2 VDC at the output plug of the PS, and the green led is lit when plugged in. I have considerable...
Well, let's try to do this.
  1. Remove the drive itself from your ODD
  2. Install it on your desktop PC
  3. Configure setup to keep the drive as slave
  4. Boot up
If the computer boots normally, without errors, it means that te PCB in your external unit container is broken. Get a new container.
If there are errors during boot up, it means that your disk's controller is broken, or there is a problem with your disk hardware. In that case, i recommend that you take the disk to a data recovery expert, They are expensive, but if you have really important data, it's the best way to keep you away from headaches :)
Also, don't attempt this solution if you haven't basic electrical working skills -high voltages may be dangerous for you-
Best Regards
Mariano
Dec 07, 2010 | Maxtor Hard Drive
Imagerunner 5000 error code e000202 , what mean ? thank
This error code is referencing your scanning lamp just beneath the document feeder. Specifically, it is stating that the home position sensor that detects when the scanner assembly is to the further most left side is malfunctioning. However, as a copier technician, I would advise against pursuing any sort of remedy yourself, as there are numerous high voltage components on the scanner assembly that present a possible danger. Not to mention replacement parts are extremely expensive if you accidentally blow anything out.
My advise, contact someone who is trained in servicing these machines.
Oct 30, 2010 | Canon imageRUNNER 5000 Copier
What does it mean when the check control light on my 1998 328 I
the cars computer has detected a problem --need to have car scan most auto stores such as auto zone/ advanced auto offer this service for free the trouble code will direct u towards repairing ur car
Jun 23, 2010 | 1999 BMW 328 Series
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
243 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
