Question about ASUS Eee PC 900 Notebook
My pc is broken asus eep 900
It says file missing or corrupt windows root/system
  • helen_doodso Jan 02, 2009
    iam getting a new hard drive for my eee pc. Can someone tell me what I will have to load to have a working pc
Missing or corrupt windows root system needs to be fixed
Really? What does F9 do? This is a lot of work. Anyway, here we go.
If you have a MS Product key sticker on the computer, and you must. Check which version you have. It might be Windows XP Home.
A free legal Windows image can be downloaded here.
http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/. The site has links for various Win 7 versions. IT MUST BE THE SAME VERSION as the product key.
Next download this tool, and make a USB Win installation drive.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Next change BIOS to boot from USB drive. Choose Repair computer when it comes up. Then choose command prompt. Type sfc / scannow ENTER. This System File Checker. It finds and replaces corrupted system files.
If this fails you still have a Windows image to work with. There are many steps, so hope all goes well.
Oct 11, 2012 | ASUS Eee PC 900 Notebook
Eee pc 900SD. It wont boot up. say's file is missing or corrupt. \WINDOWS\SYSTEM32\CONFIG\SYSTEM. There is no cd\dvd rom so can i use flash drive or memory stick to replace that file? Cheers Don.W.
systems32 is part of operating system. and your computer is corrupted. Only solution is to reformat your computer by installing fresh operating system. Don't worry, you can borrow from any of your friend his EXTERNAL CDROM or DVD DRIVE to reformat your computer.
Dec 17, 2010 | ASUS Eee PC 900 Notebook
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
Windows root system - file is missing or corrupt. help!!
If you can repair the windows then boot with original OS cd and follow the instructions that how to repair installed windows.
If this repair process unable to fix this issue then you need to install a fresh copy of Windows. But remember if you want to install fresh copy, you will be unable to access your previous data on your drive C:\
Best of luck.
Regards;
Hasan
Dec 30, 2009 | ASUS Eee 900 Notebook
Asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
Aug 29, 2009 | ASUS Eee PC 900 16G Notebook
NTLDR is missing
You have to reinstall your operating system or to repair it. NTDLR is a system file on the root of c: . Somehow the file got corrupt.
Apr 22, 2009 | ASUS Laptop Keyboard for Asus T9400 Series...
ASUS eeePC 900 Keeps rebooting at XP load screen.
You're computer is booting that's not your problem. Its just not booting into Windows which is a different subject, so a boot disk will not do you any good. You have some corrupted files at the Windows end not the start up end. The only way to correct the Windows corrupt files is to use a Windows disc. So you'll have to buy/borrow a portable DVD/CD player and a copy of windows. Once the Windows disc loads then its just a matter of clicking on "repair" when the disc asks..that one of the drawbacks of netbooks..If you have any questions let me know..
Apr 20, 2009 | ASUS Eee PC 900 PC Notebook
Windows could not start because the following file is missing or corrupt. windows root system 32 hal dll pls re install a copy of the...
Yes the hal.dll is one of the files it needs to boot up, It gets all of the hardware together..I own and ASUS and they pretty good about sending disk. Pull the disk out that came with the system. Just put it your CD and then go into Windows Explorer and look for that file. Its probably under i386 folder or Win32 folder. Once you find it then just drag it over to the c: drive and you are ready..I didn't get a cd player in mine, so you probably didn't either. I ended up buying one from Best Buy, it works really good, it's an HP.But anyway if you can copy that file over to the C: drive of your computer then you will be ok...it didn't way anything else did it> Let me know how it turn out..
Mar 25, 2009 | ASUS Computers & Internet
My asus eee pc 900 wont work
open the cpu cover then refix RAM then checl if problem still remains
then u have to reinstall reapir win xp
Dec 31, 2008 | ASUS Eee 900 Notebook
ASUS Eee PC 900 Notebook Logo
131 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
