Question about Canon PIXMA IP5200 InkJet Photo Printer
Will not print in black
All cartridges replaced
    President:
  • 8,637 Answers
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Posted on Jul 20, 2010
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
EPSON BX600 WONT PRINT.the trouble has occured since black was replaced.tests show colours but no black.
Remove the black cartridge and insert back into place, check out the cartridge removed from the print cartridge (where the ink comes out) should be moist, not wet black.if color print is likely to be clogged inkjet print head dry and requires a specialized intervention or replacement may involve cleaning the print head. If the cartridge is dry is not good means that the cartridge (cartridge happens when more time sitting unused in the packaging is damaged and allow contact with air.---replace cartdrige---
Apr 12, 2011 | Epson Office Equipment & Supplies
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    Black is not printing after replacing with new cartridge
    Get the printhead replaced.
    Kodak does not charge you for the replacement.
    Oct 07, 2009 | Office Equipment & Supplies
    I put the cartride in the wrong spot how do i get it out.
    Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Pull the print cartridge toward you out of its slot.
    If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector
    Regards,
    Jeep Brainy
    Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printer not working!
    Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
    Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
    Not printing after color cartridge ran out - new black cartridge installed.
    Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
    Regards,
    Bob Headrick, Microsoft MVP Printing/Imaging
    Jul 18, 2008 | Epson Stylus C60 InkJet Printer
    I can't find my manual--model C4280-----I need to replace the black ink cartridge---I've got the door open and can see the cartridges---how do I release them to come out?? Thanks, Dennis Crawford
    1.
    slot on the left.
    5. Pull the print cartridge toward you out of its slot.
    container.
    If you go here you can download the user manual.
    http://h10032.www1.hp.com/ctg/Manual/c00896316.pdf
    Jun 18, 2008 | HP Office Equipment & Supplies
    Canon PIXMA IP5200 InkJet Photo Printer Logo
    73 people viewed this question
    old marine
    old marine
