File missing or corrupt.windowsroot\system32\hal.dll cant reboot
  • 13 more comments
  • helen_doodso Dec 31, 2008
    windows could not start because of acomputer disk hardware configuration problem
    not really
    still no nearer solving my problem
  • helen_doodso Jan 01, 2009
    yes i do have recovery cds but cant get the usb to read the cd drive or flash drive so i think i should give up and send it away to be repaired
    windows could not be started because of acomputer disk hardware configuration problem, could not read from the selected boot disk
    unfortunately i cant get the eeepc to recognise the flash disk which has the recovery cd copied on it. just cant find away to get in to reboot
    eeepc laptop not working cant get it to recognise the flash drive to correct the situation
    idont have acd of my windows and i think somehow i have to get a remove windows onto a flash drive and then reininstall linux. i got the flash drive to work but irt hasnt made any differnce as windows is blocking the linus reboot
    my cd s dont worki really nneed to uninstall windows professional by gettting on to a flash drive but dont know how to go aboout it any ideas please
  • helen_doodso Jan 02, 2009
    i am buying a new hard drive for my eee pc and now need to know what i will have to load to get my pc working again any help with this would be appreciated
    irelly need help with what i need to put on a new hard drive for my eee pc so that it will work
    Iam getting a new hard drive for my sick eee pc . Can anyone give me any advice on what i need to put on this to get me pc working
    dont think this reply was meant for me if it was it wasnt in reply to my latest question. what do i need to load on a new hard drive for my eee pc
    Please can anyone tell me what i'll need to try to load on a new hardrive for my eee pc. I would like to get my pc working again
    I DONT HAVE WIN RECOVERY ONLY LINUX
  • 10,515 Answers
FOLLOWING IS UR ANSWER :)
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
  • The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears.
    Cause Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Resolution
    1. Restart the PC. The hal.dll error could be a fluke.
    2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
      If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
    3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
    4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
    6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
    7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
    8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
      If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
    9. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
    Applies To This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
    Still Having Hal.dll Issues? Let a community of PC support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums. Be sure to let us know what steps you've already taken to resolve the "missing or corrupt hal.dll" issue.
    Other Errors That Appear During the Boot Process "NTLDR is Missing"
    More DLL Topics What is a DLL File?
    More DLL Errors Kernel32.dll ErrorsNtdll.dll ErrorsIeframe.dll Errors
    THANKS.
    Posted on Dec 31, 2008
    • 19,396 Answers
    You need to reinstall Windows.
    If you want to do it yourself, use an external CD. Otherwise send it for repair.
    You may lose your data, if you want to rescue and secure the data you must use a boot cd with tools, or remove hard disk and do a backup usng a different computer.
    This are not user level operations, and it is better having the job done at a repair shop.
    Posted on Jan 02, 2009
    • Ginko
      Ginko Jan 02, 2009
      You do not necessarily need a new hard drive, this wont change anything.
      New or old hard drive you need to install files into your hard disk.
      Novelist:
    • 163 Answers
    K..
    there is a very simple way to recover your system file--
    1) download the file from the given link --
    http://www.dll-files.com/dllindex/dll-files.shtml?hal
    2) simpley past the file on c:windowssystem32hal.dll (past here)
    note if your operating system is not working then try to boot your system using another bootable CD and past the downloaded file to the given root.
    Thanks
    • 758 Answers
    I am sorry to hear that about your computer...unfortunately in order to solve that problem you will need to reinstall windows..Hopefully you have the reinstallation disk..If you dont have it, please contact your computer manufacturer to obtain the disk..
    I hope that helps
    Thank you
    Computerrep
    Posted on Jan 01, 2009
      Problem Solver:
    • 59 Answers
    When you turn the computer on there should be a writing (system recovery F10,11or12 just press it and it should recover your pc good luck hope this helps
      Brigadier General:
    • 6,966 Answers
    Hi and welcome to FixYa,
    Offhand, I believe the simplest would be:
    • get hold of a SATA/IDE HD to USB adapter appropriate/matching the HD of your computer;
    • remove the HD of your computer and connect to the SATA/IDE HD to USB adapter;
    • presumably, there is a 2nd PC and hopefully likewise using the same OS;
    • connect the HD + SATA/IDE HD to USB adapter to the 2nd PC;
    • copy the missing file(s).
    Good luck and Thank you for using FixYa. Happy New Year.
      Genius:
    • 1,913 Answers
    U have to reapir win xp
    if u have win xp recovery then repair win xp
    • 15,935 Answers
    Hi genevive, That's a critical file (as you've discovered). There are lots of ways
    to get it back to where it belongs. The easiest way would be if you had an original
    Windows INSTALL CD. It doesn't need to be the one corresponding to the install on
    the hard drive - a borrowed one will work. If you can get one, use the Recovery
    Console
    and type chkdsk /r at the C:\> prompt. That should replace it.
    You can also just copy the file from another PC onto a floppy, and use the Recovery
    Console to copy it into the C:\Windows\System32\ folder
    Another option (if you don't have a WinXP install CD) is to make a Bart PE Boot CD from
    another PC with a CD burner, use the boot CD to boot up your friend's machine, and
    copy the file from the floppy to it's proper folder.
    Another option would be to take the hard drive out of the disabled machine and hook
    it up as a slave drive in a good machine, and just copy the file over that way. I
    actually chose this option first once when this happened to me, but both machines
    were already open.
    Hope one of these choices works for you.
      Genius:
    • 1,142 Answers
    Resolution
      Genius:
    • 1,239 Answers
    Hi
     boot from the CD/DVD." Are you sure that the cd/DVD is ok. ? If the original CD is a bootable disc then you have no problems . You should reinstall using the original CD.
    1. at frist boot, press'F2" of "Delete" to enter the bios setup.
    2. find the first boot setting and change it with CD rom and then pres "F10" to save and exit the setting.
    the sytem will restart automatically. then press any key to boot from cd rom.
    You are done.
    please tell me the problems if this solution won't apply i will give you further solution.
    best regards, melnavz
    • 470 Answers
    Do you have a cd of your windows?? ok during reset, if it will shown press TAB for bios, press it then choose the cr-rom and put it on the number 1. then put your CD then restart, and the installation begin, if there any clarrification just tell me
    • 1 more comment
    • Antonio Buenafe Jr.
      Antonio Buenafe Jr. Jan 02, 2009
      it is simple, buy CD, of windows xp professional,, then after reeboting, prioritise the cd-rom click it then press the minus sign "-" until it place to the number 1.
      like this 1. CD-rom then insert your CD, and then restart it. and the installation begin!!
      you know after putting it the hard drive, you must install the operating system because it is the first thing to do, after it, that's the time you install your new hard drive
      Antonio Buenafe Jr. Jan 03, 2009
      if you dont have win xp repair?? why did you rate it as FIXYA???????
      Master:
    • 416 Answers
    Try starting up with a boot disk, then at the prompt type
    fdisk /mbr this will refresh your master boot record. Give that a try, then try a reboot. Boot disk you can create from another PC running XP
    Here is more infor
    http://www.kellys-korner-xp.com/xp_haldll_missing.htm
    If it not help you can try here
    Good Luck
    • 3,037 Answers
    Hello helen_doodso
    Please go to the following link and download the file given at the link
    http://support.microsoft.com/kb/320252
    let me know if you have any more questions or if you are having trouble still with this
    bestdarngood
    • 2 more comments
    • Benjamin Patri
      Benjamin Patri Dec 31, 2008
      do you have the startup or recovery cds?
      You will need to use them and you will need to download the file onto a flash drive or cd from another computer and try to get them on the computer in question.
      Also, I assume you can get into the setup/bios at the startup and can start in safe mode, correct? If so, this would be your best option at getting this working, let me know if you can do this and what happens. I'm sorry it took me so long to respond.
    • Benjamin Patri
      Benjamin Patri Jan 01, 2009
      So even by pressing F1 or F12 depending on the laptop, you can't even get into the setup menu immediately after you turn it on? That error message displays before anything else?
    • Benjamin Patri
      I'm saying, without a disk and without a flashdrive, can you get into the setup mode on the computer? Do you know what I am talking about?
    • Benjamin Patri
      Benjamin Patri Jan 02, 2009
      you will need the operating system Cds to install the operating system onto the new hardrive for one, this is the main thing.
      then you can put anything else that you want on the computer from there.
      President:
    • 2,110 Answers
    Http://www.dll-files.com/dllindex/dll-files.shtml?hal
    download hal.dll from here and paste in \windos\system32\
    • 6 more comments
    • Sibananda Jena
      Sibananda Jena Dec 31, 2008
      http://www.dll-files.com/dllindex/dll-fi...
    • Sibananda Jena
      Option 1:
      Boot from your CD and follow the directions to start Recovery Console. Then:
      Attrib -H -R -S C:\Boot.ini
      DEL C:\Boot.ini
      BootCfg /Rebuild
      Fixboot
      Option 2:
      Boot from your CD and follow the directions below to start Recovery Console.
      Insert the Setup compact disc (CD) and restart the computer. If prompted, select
      any options required to boot from the CD.
      When the text-based part of Setup begins, follow the prompts; choose the repair
      or recover option by pressing R.
      If you have a dual-boot or multiple-boot system, choose the installation that
      you need to access from the Recovery Console.
      When prompted, type the Administrator password. (if you didn't create one try
      pressing enter).
      At the system prompt, type Recovery Console commands; type help for a list of
      commands, or help commandname for help on a specific command.
      Most likely you will need to expand the file from the CD. The command would be
      expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive
      letter of your CD. Once you have expanded the file type "exit" to exit the
      Recovery Console and restart the computer.
    • Sibananda Jena
      Sibananda Jena Jan 01, 2009
      Usb drive is not required only recovery cd is needed,You have to boot from CD and follow my previous post..
    • Sibananda Jena
      have u changed the boot order in BIOS to CD drive as first boot device...
    • Sibananda Jena
    • Sibananda Jena
      Sibananda Jena Jan 02, 2009
      So I may be late on this, but I found it difficult to find the
      information via google. The following is the method I used to make this
      happen.
      I have a Fujitsu laptop with a 60g disk drive. I got a
      bunch of spyware and a couple virus' that I couldn't get rid of, so I
      needed to do a fresh XP install. The dvd controller went bad on the
      motherboard and I didn't have a floppy drive or external cd drive so I
      used a 20G USB drive instead. It was really quite simple. (provided
      your bios supports booting from USB devices.)
      *NOTE - after
      doing this, my root drive on the laptop is now D, instead of C. I
      followed directions on M$ support page, but this caused issues and had
      to reinstall.
      So here it is:
      Tools/Hardware needed:
      external USB drive large enough to hold the contents of the WIN XPSP2
      disk and space for the setup files when you initialize the fresh
      install.
      1 WINXP SP2 setup disk. (i used my backup copy that i'd made from the original)
      1 WIN98SE boot disk IMG (i obtained mine from bootdisk.com)
      Boot files from an XP machine or disk (NTDETECT.COM, NTLDR, BOOT.INI)
      A program to view the contents of the WIN98SEC.IMG. (i used the trial version of MagicISO)
      HP USB Disk Storage Format Tool
      Steps:
      On a working xp computer, connect your USB disk drive
      Open your WIN98SEC.IMG and copy the files to a directory on a working 2k/XP computer.
      Use
      the HP USB format tool and format using FAT32. Select the option for
      the DOS startup disk and point it to the directory where your WIN98SEC
      files are.
      ***after the format is complete, you should have a
      bootable USB drive with the needed commands to format the hard drive
      needing the fresh XP install. you should test this now to be sure***
      *Note,
      You may need to manually copy over the other files from the WIN98SEC to
      your USB hard drive as the HP program only adds the MS-DOS startup
      files (i think). Either way, if they're not there after the format,
      copy them over.
      Make a folder on the root of the USB drive
      called "WINXPPRO" Copy all the files/directories from the WINXP SP2
      disk into this folder.
      Connect your USB drive to the computer you will install XP on.
      Make sure you set your bios to boot from your USB drive.
      Boot your computer to the command prompt. (my option was pressing Shift+F5)
      ***at this point your USB disk will be drive C, drive to install windows on will be D, and will be referred to as such***
      From C:\ type SMARTDRV. Do this from the command prompt everytime you reboot. This will help things run quicker (i think).
      We now need to format and partition D. (we'll have 2 partitions. A Primary (D:), and an Extended (E:) From C:\ type FDISK
      Create a primary partition on your D: drive (mine is 6G)
      Create an extended partition of 900MB (will be known as drive E:)
      Leave the rest alone for now
      Reboot
      Format both D: and E: as FAT32 partitions. (from C: type FORMAT D:, reboot, then FORMAT E:)
      Reboot
      We now want to get the WINXP SP2 setup disk files to E:
      At the command prompt, type E: to make sure you're on that disk
      type MD WINXPPRO
      type XCOPY C:\*.* /A /E. This will copy everything over to your E
      drive. (this took a couple hours when i did it since it copied over
      7,000 files including directories)
      Reboot
      Now you have
      all the files you need on your E drive to run setup without worrying
      about the USB drivers loading when you setup XP.
      from the C:\ prompt, type E:
      E:\>
      type SMARTDRV
      type CD WINXPPRO
      type CD I386
      type WINNT
      *Note - you'll need to keep your USB drive plugged into the computer until after Windows is installed completely.*
      WINXP
      setup will now run. It should automatically show that E:\WINXPPRO\I386
      is the location of the windows files. If not, change it so it is.
      let
      setup do its thing. when the computer reboots, you'll see 2 choices to
      boot to. 1 is XP upgrade/setup, the other is WINDOWS. Always choose the
      XP UPGRADE/SETUP option.
      Choose the 6G partition (D:) to install Windows on. When asked to format, choose FAT32 (you can upgrade to NTFS later).
      Setup
      will get to a point that asks for file "asms" on the SP2 CD. it will
      give a default option of GLOBALROOT\.....\.....\DEVICE\.....\I386 (or
      whatever).
      Type E:\WINXPPRO\I386 (you may want to highlight and press ctrl+c so you can paste it from here on out) and press enter.
      Whenever a dialogue box pops up asking for a file, just paste the E:\WINXPPRO\I386 in there and press enter.
      Once
      windows setup completes, you will be able to use your C: to boot to
      WINXP. Once you have verified this, log on to Windows XP, take your XP
      boot files (NTDETECT.COM, NTLDR, BOOT.INI) and paste them on the root
      of D. Then go to Disk Management, select D and make the partition
      active. This will allow you to boot XP without your USB drive attached.
      You
      can then go in through disk management and delete the E: partition and
      create a large extended partition for all non-system files and
      programs. This keeps everything separate in the event that you should
      have to reload the OS at a later time.
      Voila! should be done now. Install your drivers and programs and let it roll.
      Like I said earlier, you're windows root is now D: instead of the normal C, so keep that in mind when installing new programs.
      I
      tried changing the root drive letter from D: to C: using instructions
      from the M$ support site, but hosed my install and had to start over
      from setup.
      Hope this is useful to some people. Email me with questions/comments.
    • Sibananda Jena
    • Sibananda Jena
      u need to have to put a CD rom to install xp once again...
    Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
    I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
    Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
    Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
    Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
    Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
    Nov 29, 2010 | Computers & Internet
    Keep getting this message <window
    • "Windows could not start because the following file is missing or corrupt:
      <Windows root>\system32\hal.dll.
      Please re-install a copy of the above file."
    • "<Winnt_root>\System32\Hal.dll missing or corrupt:
    The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
      Please let me know you have any further questions or concerns.
    Thanks.
    May 08, 2010 | HP Compaq 6720s Notebook
    Missing file or corrupt in system32 hal.dll
    Dear User,
    Try to download the hal.dll file from here.
    You will get one popup download the file after donwloading you have to unzip to c:\windows\system32 folder.
    Mar 03, 2010 | E-Machines eMachines Desktop PC
    Motherboard 400M01 series - windowsroot\system32\hal.dll corrupted - don't know how to recover system from this error. It won't reboot - tried hotkey super recovery,etc. Nothing helps - my knowledge is...
    Here's a very useful page which explains how to troubleshoot this error:
    http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
    Go through the list of suggested solutions. One of them should fix your problem with the corrupted hal.dll
    Dec 03, 2009 | Foxconn Computers & Internet
    Systemroot/32 /hal.dll missing
    You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
    Nov 15, 2009 | Computers & Internet
    I am installing a recovery disk for an emachines computer and i get error message stating that the system 32hal.dll is missing or corrupt. i cant get back to the windows screen to install the missing file...
    You have to start your PC with the XP cd-rom install disk, if you have
    one.
    Then, when you come to the screen with the following option displayed :
    To repair a Windows XP installation using
    Recovery Console, press R.
    Then press [R] to start 'Recovery Console'
    When confronted by a prompt asking you for Administrator password - just
    press [ENTER]
    Once in RC has started - type the following command :
    expand x:\i386\hal.dl_ c:\windows\system32\hal.dll
    (where [x:] is your cd drive-letter)
    *NB If SP3 is installed - then the command you type must be :
    copy c:\windows\ServicePackFiles\i386\hal.dll c:\windows\system32
    ....instead, as the files are of two different revision levels
    (versions).
    Then reboot.
    Oct 28, 2009 | E-Machines T5212 PC Desktop
    "...missing or corrupt\system32\hal.dll..."
    Boot from windows install CD, when it loads, press "R" for repair.
    It will go out to dos.
    when it gets to dos, type: CHKDSK C: /P then press enter and let it repair, when done
    just type EXIT, it will reboot, remove the CD and see if it reboots. If this doesnt work or you need more help, let me know, i can be more detailed if you need, Im just at work and dont have alot of time to type.
    Feb 17, 2009 | HP Pavilion zt1170 Notebook
    Windows>\system32\hal.dll. corrupt
    HAL.DLL Missing or Corrupt
    If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
    Insert and boot from your WindowsXP CD.
    At the first R=Repair option, press the R key
    Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
    Type bootcfg /list to show the current entries in the BOOT.INI file
    Type bootcfg /rebuild to repair it
    Take out the CD ROM and type exit
    Regards
    Mar 26, 2008 | HP OmniBook XE3 Notebook
    Cannot play old type of cd or dvd
    HAL.DLL is Hardware Abstraction Layer. Dynamic Link Library. You will need to reinstall this file for the cd-rom to work properly. You can download the lastest version file from this web site: http://www.dll-files.com/dllindex/dll-les.shtml?hal
    Jun 27, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
    Computers & Internet Logo
    259 people viewed this question
    David Payne
    David Payne
