Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
My older dyson is so hard to push, was told there's a kluge to fix it. Where can I find that information?
Difficult to push. Dyson product demonstrator at my local Costco said this website has a tip for what to do to change the suction head area to eliminate that problem. She was great, and I bought a new ball-style dyson from her, but I'd also like to do this fix so I can enjoy using both my dysons.
    Top Expert:
  • Dyson Master
  • 54,527 Answers
Then again perhaps hair either human or pet has wrapped on the wheel axles making them bind up . only you can look at all the possibilities and fix them ,we can not
Posted on Jan 03, 2018
  • 1,216 Answers
You will be surprised how much friction dirt on the sole plate will cause, it has to be as clean as possible to glide across the carpet so definitely clean that before you move onto any other solutions, or it's damaged or simply a worn soleplate.
hope this helps.
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
  • 389 Answers
SOURCE: My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
Posted on May 19, 2009
SOURCE: no suction on dyson dc24 ball
Well i just fixed my Dyson Ball with the same problem you have. My wife and i found out it was a crumpled receipt in the lower section of the hose at the upright/handheld pivot #3 in diagram and it was catching cat hair and other things. I began by removing the canister and turned on the vacuum to see if the direct access to the fan had suction. Then i moved to #5; i reattached the canister and threw in some cat hair into it from the bottom. i turned on the vaccum to see if it spinned around; it didnt. I then moved to #4, i removed the head and then turned on the vaccum to see if maybe the head had a leak at the top connecter; as i predicted the strength was minimal. I then worked my way to #1 to see if the strength was the same or if there was a difference. no difference for us. Well then it must be #3.. of course the last one i checked. I used a small flashlight and peared in and i didnt see anything... i then used a coathanger very softly as to not puncture the hose. i then noticed some hair being pushed out but the main culprit wasnt showing. my wife gave me needle nose pliers and i pried the hose off of the top connection in #3; so i could get a better look; you may be able to push it off with your hands. and viola! a crumpled reciept for 3 Monster energy drinks.... the same ones....i drink... oops!... hopes this helps. just go through it step by step. youll know its working once stuff begins to spin in the canister. almost regretted throwing that dyson registry junk away.
Posted on Jul 22, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
SOURCE: After hoovering yesterday my dyson ball wont stand up right.
solved this today by folding the upright part back as far as it would go, and wiggling it a little. It clicked back into place.
Posted on Nov 01, 2009
Reading this blog. Dyson is of little to no help. How disappointing when you spend a small fortune on one of their products. I'm just now experiencing hard to push with. DC25 Animal. Can't adjust height....
sorry to say your dyson is not the fault, its your carpet, a lot of new carpets have a tight weave pattern, this makes it impossible to push any vacuum. all new carpets have a directional pile always vacuum with the pile. The best option is to buy a auto drive kirby it does all he hard work for you. you can pick a refurbished one up for around 300
Aug 12, 2017 | Dyson Vacuums
We had an older dyson vacuum that worked great until it had to be replaced and now our new one it works great on short carpet but is very difficult to push on thicker carpet.
Hi Ronnie, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your new Dyson vacuum on this particular type of deeper-pile carpet. It's possible your new machine has higher suction at the cleaner head, and this could mean it needs slightly higher push-force on certain carpets with deeper, denser pile, or thick underlay. You may find it helps to use the vacuum with the brush bar switched - carpet manufacturers will sometimes advise vacuuming deep-pile carpets in this way.
However, I would encourage you to get in touch with us directly so we can take some further details about the issue. When you have your Dyson vacuum easily to hand, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to discuss your concerns.
We'll look forward to speaking with you.
Jun 03, 2015 | Dyson Vacuums
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
My Dyson Absolute DC17 is becoming difficult to push
I'm sorry to hear you're having difficulties with your DC17. If the cleaner seems to have become difficult to push, you may want to check that the base of the soleplate is clean. If it appears to be dirty, you can clean it using a damp cloth - always make sure it's totally dry before replacing it on the cleaner.
While you have the soleplate removed, it's a good idea to check that the cleaner head is free of blockages, and that the brushbar is free of any threads or hair. For guidance on removing the soleplate and performing these checks, please see follow the steps shown in our support guide:
http://www.dyson.com/support/help.asp?article=955&product=DC17-ANIMAL
If the soleplate appears to be damaged, or if you find that following these steps doesn't resolve your issue, please get in touch with us directly so we can provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Sep 07, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Very hard to push. It started gradually but now its nearly impossible to vacuum the carpet. Is this an easy fix?
I'm sorry to hear you're having difficulties with your DC17. If the cleaner seems more difficult than usual to push, it's a good idea to check the soleplate for damage, and to remove any threads, hair and other obstructions from the brushbar. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=961&product=DC17-ANIMAL
You may also want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brushbar. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further questions or concerns, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Aug 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
THE ROLLER BLADES ARE DIFFICULT TO ACCESS PLUS THEY GET CLOGGED TOO EASILY. i CAN'T ADJUST THE CARPET HIGHT???
Sorry to hear you're having difficulties with your DC07. I can confirm that the cleaner head has been engineered to adjust automatically for optimum pick-up on different floor surfaces, without the need for manual adjustment. The brush control allows you to turn the brushbar off when needed, to protect hard floors, delicate rugs, or plush-pile carpeting.
If you need to clean hair, threads or other obstructions from the brushbar or cleaner head, removing the soleplate will allow you greater access. Our online guide shows you how to do this:
http://www.dyson.com/support/help.asp?article=126&product=DC07-SY-HEPA_US
If you need any further advice on maintaining your DC07, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 19, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
New Dyson hard to push
Sorry to hear you're having difficulties using your DC14 on this particular carpet. It might help to check you have your brush control adjusted to the correct setting - you can find out how to do this in the user guide supplied with your cleaner. In case you don't have this to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
You may also want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson dc07 seems to be very hard to push on carpet boy ont tile?
Sorry to hear you're having difficulties using your DC07 on this particular carpet. It might help to check you have your brush control adjusted to the 'Carpets' setting - you can find out how to do this in the user guide supplied with your cleaner. In case you don't have this to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
Kind regards,
Jack
Jun 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Carpet roller brush not going round
Sorry to hear you're having a problem with your DC25. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1566&product=DC25-ALLFLOORS
However, if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Apr 01, 2011 | Dyson DC25 All Floors Bagless Upright...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
78 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Etronix
Level 1 Expert
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
