No heat I have a Singer Unit MDL # bce22008 Ser # R463. One element is open and the other reeds cont but it is not heating. Whats going on? Do you know where I can get parts , or another unit?
  • techmelvin May 11, 2010
    Is this a split system? Singer has not made Central AC units in over 15-20 years. Parts are no longer avail. As far as the heater you can buy whats called a re-string kit. But I don't recommend your average home owner attempt that. Most AC companies can do it.
mastatech
  • 478 Answers
SOURCE: Heating Element on my A/C not getting hot
It definitly did not open the element the 24vac isn't enough. I would go back over the wiring.When your t- stat calls for heat you want it to energize both sequencers. the easist way to assure this is to connect the whiet and purple two gether at the a/h.
Posted on Mar 14, 2009
  • 534 Answers
SOURCE: Heat / Cool unit runs approx 45 minutes then trips the breaker
Check the amperage of the breaker or change the breaker out completely with a new one. The tripping problem is that the breaker itself is heating up to the point that the bi-metal in the breaker (safety device) is throwing the breaker off. This could be the problem for you however, I would get an ampherage draw from the unit to insure that the breaker is the proper size for the unit. If you can find what kilowatt the unit is divide that number by the amount of current being supplied and that will give you the breaker size.
Good luck hope I helped you some
Dave
Posted on Jan 08, 2010
hvac1960
  • 2133 Answers
SOURCE: This is a heating and cooling company looking for
You're right. The eating element always be behind the evaporator coil.But check whether your unit model has heating and cooling or cooling only.
Posted on Dec 15, 2010
hvac1960
  • 2133 Answers
SOURCE: Fan Coil Unit 488L-Ser#F2RP042N06B,Motor 3.8FLA,
Replace your fan capacitor immediately.
Posted on Dec 28, 2010
vetteman3002
  • 2299 Answers
SOURCE: My heating element and fan
This is a question that I can help you with. I am a Master Electrician. I have wired hundreds of houses. But I am going to need a little more information. Does the switch to turn the heating elements and fan as the exhaust fan? Or is it on a separate switch?
Posted on Jan 10, 2011
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but...
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
Jun 04, 2017 | Amana PTC153B50AJ Electric Heat Air...
Oven takes approximately 35 minutes to heat up to 350 degrees.
if this is all the higher it heats,its one of 2 things,first the heating element could have a Hot-Spot on it somewhere(a dis-coloration) on the element and have a bubbly/pock marked area that ready to burn out and cont pass enough current to fully heat the element,number 2 it could be the thermocouple on the roof of the oven cavity that is bad and turning off heat before its to the heat you set,it looks like a long tube with a wire or smaller tube leading from it,its connected to the oven heat control and senses oven operating temp and cycles the heat on and off per your temp setting
Aug 01, 2010 | Maytag Kitchen Ranges
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Have a Frigidaire FDE647RFS1 dryer Dryer tumbles but no heat How do I fix this? Could it be the Thermostat Safety or the Thermal Limiter? Are these items hard to replace?
on housing element ther is a fuse check cont, if open its bad you can allso temp bypass to test if still nothing element is probably bad but most dryers over 15 years old have that safety fuse incase vent stops up besure and fix duct if fuse is bad free advise at allbrand appliance ser 502-410-9919
Derald Haney
Jan 20, 2010 | Dryers
I have a matag cre9600cce, the oven heats, but very slowly and not all the way. i set it to 350 and after an hour it is only at 210
the cre is elect so look for one of the elements not working / ( bake ) is probably is out . and the pre heat is only from the top element .. / test by open door ser to bake bottom element should go red / then set broil and it to should turn red . the one that does not repl .. mm
Dec 12, 2009 | Amana ARGS7650SS Gas Kitchen Range
Dryer wont heat
First answer is yes; high resistance is good. I am not sure I understand the second question. The reasion one has to isolate the element is to avoid resistance from other parts. This, I believe , is the most likly problem.
Dec 26, 2008 | Maytag SDE2606 Electric Dryer
Dryer
Probably the heater element. You need to pull the back of teh machine off and check the heating element for continuity. If its open then its shot.
These are parts that normally go bad.
Check on ebay these can be had for less than 50.00
Oct 03, 2008 | Amana ALG331RAW Gas Dryer
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
