Question about Dell W5001C 50 in. Plasma HDTV
I had a surge the other night
Surge shut off my tv, and it hasn't gone back on, could it be only a fuse or is it more severe than that?
    New Friend:
  • 90 Answers
Do u get a blue light upon powering up? if no, its the power board. it needs replaced
Posted on Jan 29, 2009
I have a Panasonic plasma, & we just had a power outage today... every time we have one, it won't power back on. The call center is closed for the night, & I can't remember what they told me to do the last...
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
Toshiba 42" hdtv just quit
chec the power point with another electrical item... perhaps the plug has triped.. if ok i think it will be your main fuse inside the tv
Jun 22, 2013 | Televison & Video
My electric went off yesterday and when it went back on my tv wouldnt turn on it was working fine before the power cut we have changed the fuse but still nothing is there anyway i can reset it to make it...
you said you changed the fuse. (inside the tv)double check to see if its blown agian if not. keep it unplugged for about 20 minutes to reset the surge protector onboard . if you have done all that the fuse didnt protect your tv from the surge and it gone. IF ITS CONNECTED TO A SURGE PROTECTOR unplug it from that and plug directly into the wall TRY THAT FIRST let me know if this works.
Mar 16, 2011 | Wharfedale Televison & Video
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I had a power surge last night do to a storm and now my Projection TV won't turn on. Is there a surge protector inside the TV that I can reset or is the TV fried?
there are several fusses in a hitachi located in the power board if your lucky one of them took the hit you can , or have atech look for you the gma type fuse are avail at Radio Shack or your local tv shop
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
Sep 10, 2009 | Televison & Video
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
I have a wd 62725 we had a power failure last night and now i have no lamps no fans nothing tv is dead i have reset several times tv was pluged into a surge protector and all of the other items are still...
Yes, apparently fuse is blow off. You need to take off back cover of TV and follow AC cord to reach on power supply board.
Get service manual from Manual Zone for small fee, if you need detailed technical info and schematics of TV.
Apr 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Power surge
Unplug it then plug it back in and it should power up
Oct 01, 2008 | Philips DVDR3575H/37
TV wont turn on
have you checked the fuses inside the set. The power outage could have surged just enough to blow the fuse. Dont forget to unplug it when you check the fuse.
Jan 21, 2008 | RCA P52937 52" Rear Projection Television
Dell W5001C 50 in. Plasma HDTV Logo
122 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
