Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
According to geek squad- motherboard problem on hp pavillion a220
He said board needs replacing or replace computer. what causes this to happen? how do I avoid if I get it replaced? comp is about 4 yrs old. Is there a life span expectancy for computers?
  • David Preston
    David Preston May 11, 2010
    Tracy,
    Before we can venture a guess as to what caused "Geek Squad" to want to replace your Motherboard we would need to know what the symptoms were that led you to take it to them. It would also be helpful to know the Manufacturer of the PC/Motherboard and what Operating system you are using. I'd ask them to explain to you what on the Motherboard faulted that it needs to be replaced.
    As for the life expectaecy of a Motherboard. It varies by manufacturer and board. I've seen some that are 15 years old and going strong and I've seen some that go bad in as little as 6 months.
    Hope this helps,
    Dave
    Scholar:
  • 76 Answers
If you've been told the motherboard needs replacing it could be true, especially in older laptops. Thinks get hot, brittle, and then a circuit gets broken. I recently had new motherboards installed in two Dell Inspiron 8200 computers. I found the boards on ebay for $70 ea. and had a local shop install them for another $70 ea.
Keep in mind Ram and video cards are common failures too.
There are quite a few diagnostic utilites out there to check for yourself before replacing the motherboards. If you want to spend the time look for ones from your computers manufacturer.
Let me know if this helps you
Posted on Dec 31, 2008
My smps is working, but my power is not coming to the mother board
Replace the power supply or have it tested.
Amazon com bestec atx 300 12z You can get a replacement pretty cheap. Most all power supplies can also be tested - Bestbuys geek squad or a small computer repair shop should have the means to test it.
Feb 23, 2013 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Hello, I have a HP Pavilion s3100n and at first it worked fine until according to Geek Squad at Best Buy said it was my motherboard, so HP replaced it and it worked great until now im haunted yet again...
If you don't see power indicator turned on or neither listen to CPU fans working, maybe the power supply is failing now, you could claim your warranty again if it's into the valid period, you could also check that all cables of your computer are securely connected.
Feb 27, 2011 | HP Hewlett Packard Pavilion Slimline...
MY HP LAPTOP WENT OFF AND CANNOT BE RESTART AGAIN
According to my experience ur if ur tv tuner card is attached than remove it and try to turn on. Even though if its doesn't turn on than U need to remove pcmcia card and try to turn on. if all this fail than ur motherboard is dead.
Jul 27, 2009 | HP Computers & Internet
Gateway PC screen blank, geek squad diagnosis motherboard issue
You could replace the motor board for less than $100 but I think the geek squad says the motor board is bad on every computer that doesn't start right up for them so I would have someone else look at it first. Or just get a new computer at walmart for like $300
Jul 23, 2009 | Computers & Internet
Screen black. best buy/geek squad diagnosis=motherboard bad. part#, price & availabilty of motherboard. installation instructions too please. thanks, t
Well if you wanting a gateway motherboard you going to be digging a little more into the pocket book, May i suggest you buy a upgrade kit from a place called tigerdirect.com or frys.com price would be under $200.00 Availability would be depending on the shipping method you use and how to install this :
Unplug everything open the case, unplug and label you cables! From all sources on the motherboard take a phillips screw driver and unmount the main board. Place the new board reversing these steps. If you need more assistance please CHAT with us we are here 24/7 and will run you step by step for a small fee.. or take it to the GEEK squad and have the motherboard installed around $45 bucks..
*We are not compensated for this email or solution so please rate.. We rely on good ratings..
May 15, 2009 | Computers & Internet
My new battery won't take a charge. HP Dv1170us
Are you sure everything is plugged in correctly? Look on the cord and make sure there are no "shorts" in it becuase sometimes it can have a "short" circuit to it, even if it's new!
Feb 26, 2009 | HP Pavilion dv1170us (PR425UA) PC Notebook
No Sound on computer
sound card on laptops are mostly built-in the motherboard, thus, not replacable. try reinstalling the sound card driver software.
Oct 24, 2008 | HP Pavilion DV6405US Laptop
Can the geek squad fix my dell computer?
Stay away from geek squad.. a bunch of **** with all honesty.. You might get one good tech out of 20. Reply back with an exact model number.
Jun 15, 2008 | Dell Inspiron XPS M140 Notebook
Compaq Laptop Overheating
sounds like you need another motherboard or prepare to get out the solder iron and correct yourself.
geek squad will not solder back on connectors, what you should do is take it to the local pc repair place and they might solder it back on. call around and ask if they can solder a component back on, it might take a couple calls to find one that will.
Jun 11, 2008 | HP Compaq Presario V2000 Notebook
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON!
Christine.
Go back to best buy. the closest one to you. and see about yoru exteneded warranty. Toshiba dont deal with the extended warrentys.A 3rd party company is looking after it for you (best buy) i guess geek squad.. If the warrenty is out and you gotta pay 600 dollors to replace your computer motherboard. all depending on what you use it for an entry level laptop is close to 600 dollors great for web browseing and office use school, some games.
Feb 14, 2008 | Toshiba Satellite L15-S104 Notebook
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
339 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
