18 " chainsaw
The dealer could well be correct, if a two stroke engine has an air leak through a seal or gasket, it will draw air through here and not through the carb, this in turn will weaken off the mixture and cause high running at idle, there are other reasons, like the throttle flap is not closing properley, or the throttle cable is not correctly seated, remove the top cover and turn the throttle shaft manually to the idle position.
SOURCE: my 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
SOURCE: johnsered chainsaw 625
I think a duplicate question… duplicate answer
This thread says a Jonsred 625 is a Husky 61. Post 17 by SawTroll can be taken to the bank. Everyone defers to him regarding specification questions.
http://www.arboristsite.com/showthread.php?t=103127&highlight=jonsered+625
I found an Operators manual here (no IPL):
http://www.tilton.usa.jonsered.com/node246.aspx
There are a number of model 61s starting on page 11. I suggest you contact Husky for clarification of any saw older than 2000. They may even provide the correct IPL for saw (Jonsered owned by Husky).
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
That said, the 61 has an outboard clutch. This will help you with removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
HTH
Lou
SOURCE: Husqvarna 359: Has run fine for 3 years. Now when
I think an air leak and she is running lean. Maybe time for some pressure/vacuum testing. Continuing to tweak the carburetor may camouflage a larger problem until the saw fails.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: Chainsaw ran out of gas. Filled tank will not
Those saws are very finicky. First shake the saw very vigorously, as the saw running dry mayy have sucked dirt to the intake screen. Clean the plug and check gap. Prime, choke and pull till it starts. your plug may be foulled, this happens alot when a saw leans out from running out of fuel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: My 455 Rancher Husqvarna 20 inch chainsaw wont
Carb adjustmwnt requires a special tool and a tacho, the saw is set from the factory for the best emmisions, however it may need a small adjustment, this should be done by a qualified dealer, incorrect adjustments can damage the engine.
