Question about Jensen VM9411 Car Video Player
Jensen 9411 WILL NOT LOAD ANY DISC
I HAVE HAD MY TV FOR ALMOST A YEAR NOW AND ALL OF A SUDDEN TODAY IT WILL NOT LOAD ANY DISCS EVERYTHING ELSE WORKS BUT IT JUST WONT LOAD IT WILL GO IN HALF WAY AND SOME TIMES IT WILL GO IN ALL THE WAY BUT WONT LOAD **NEED HELP ASAP**
  • 1 more comment
  • SCOPE J Dec 31, 2007
    everything work but want load disc
  • Anonymous Feb 08, 2008
    I recently just had this problem. I believe my unit is more than a year old, is there any other fix for this problem??
  • sand_duner Mar 05, 2008
    Same here, just over a year old and won't take a disk
It's a problem that a lot of people that have this unit is having, the solution is repair center and not to purchase this unit anymore it problem that Jensen audiovox need to use better parts
Posted on Nov 26, 2007
The DVD player built into the unit has suddenly stopped working. We can load and eject as normal, but it doesn't play the disc. Pressing PLAY displays the "No disk loaded" message.
Disc do not loads into it properly. Is a loading mechanism fault. Contact any service technician. The disc loading mechanism should take out from the set for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 03, 2015 | Televison & Video
My disc will not load in my new vx 7020 jensen navigation care stereo. its new.
Even new is defective some times. If everything works on the stereo, except the disc player. return it.
Jan 09, 2015 | 2007 Nissan Sentra 2.0 SL Sedan
I have a Jensen DV2007 CD/MP3/WMA/DVD Player/Receiver and was wondering if it will play my Sony DVD-RW 3"mini disks
No they will not work as the loading mechinism would not be able to grab ahold of the discs. Normal cd/dvd's load because the mechanism grabs by the sides of the disc and the 3'" disc would be to small.
Sep 21, 2010 | Jensen AM/FM/CD/MP3 PLAYER WITH DETACHABLE...
Jensen's VM9312HD when i put the disc say's bad disc
it might need a lens cleaner disc...this is a common problem of using discs
Aug 10, 2009 | Jensen's VM9312 Car DVD Player
Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Car Audio & Video Logo
180 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
