Question about Weather King 12AJA4801AH Air Conditioner
  • 242 Answers
I can help , If your positive there is 5psi + of gas going to the unit and you have tied the red low voltage wire with the white low voltage wire or R term. to W term. on the board or low volt. term board together and there is still no gas the problem is a bad gas valve , they are notorious for failing. Hope this helps you out , let me know if you have any more questions or problems. good luck Phil
Posted on Dec 31, 2008
I have a Armstrong SX80 gas furnace, T-stat calls for heat, combustion fan starts, in 1 1/2 min burner lights,this month t-stat calls for heat, combustion fan starts no burner ignition,
Check pressure switch and hoses to it . check air filter is clean . check you have gas in the line . check connections on gas valve check flame sensor
Dec 05, 2017 | Heating & Cooling
My furnace will not ignite
If it has a glowing igniter, that must mean it is a Gas furnace?-- LP or Natural Gas?-- We need to establish a few things like:
1.) Is there a good supply of Gas?
2.). When the Igniter starts to glow, can you hear a gas valve click'?- and then is there a small flow of Pilot gas? (over the area where the burners will need to flow gas-- so the gas in the burner tubes can be ignited safely.)
3.) There is a circuit somewhere in there, that detects that you have established FLAME-- (Usually a 'flame rod' that allows the main gas valve to open.) Can you see the 'pilot flame' touching that rod? A very small electric current is actually conducted thru the flame, -- completing the circuit that allows the safety circuit to go to the next step, before it opens the main gas valve.)
These things have to exist, before the safety circuitry allows the main gas valve to open.
Tell us more, what you observe, as you try to start it again.
Mack B
Nov 29, 2016 | Heating & Cooling
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
Light pilot reset
If yours is a high-efficiency furnace, you should hear the stack blower start running when your thermostat calls for heat. Next, the igniter should start to glow and remain glowing until the thermocouple opens the gas valve and allows gas to flow to the main burner. The main burner lights and burns until sufficient heat is generated for the main blower to turn on and blow warm air through your house. If any action does not occur in the order described, repairs are in order.
Dec 08, 2013 | Kitchen Appliances - Others
My goodman furnace keeps lighting for about 10 seconds than goes out lots of clicking sounds
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad igniter what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas.
Solution: You probably need to purchase and install a new igniter. I would suggest that you inspect your igniter closely for cracks. Make sure you do not touch the igniter with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, roll-out switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
NATE, NCCER, PHCC,HVAC Certified Instructor
Oct 25, 2010 | Heating & Cooling
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
Hi, my problem is i have gas (propane) to the valve ,it has electric ignite , also hook up to a remote system i do not have the remote, there is a bypass setting,the igniter works still no pilot light.i...
The gas company should have have set and adjusted the gas pressure when they installed the new regulator. DO NOT ATTEMPTED TO LIGHT THIS WITH A LIGHTER. If this furnace has a hot surface igniter you and you lighter will be energized with 120 volts...BE CAREFUL...
If this furnace has a spark igniter you and your lighter can be lit up with up to 10,000 volts.
Since this furnace sat inoperative for so long I will bet that you have a blocked pilot assembly. Turn off the power and the gas. Carefully remove the pilot assembly. Dismantle it. Inside you will find a very small orifice Clean it out. Put every thing back together. The furnace should work.
The clunking noise you heard was probably the gas valve trying to open.
Feb 19, 2009 | Heating & Cooling
Weather King 12AJA4801AH Air Conditioner Logo
61 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
