DeLonghi MG15T SafeHeat Oil Filled Radiator Heater Logo
A
Anonymous Posted on Oct 13, 2012
Operating manual for delonghi dragon 2 heater
5 Related Answers
Anonymous
  • Posted on Jul 13, 2011
SOURCE: Hi i have a new DeLonghi Dragon 3 heater. The
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
ginko
Ginko
  • 19396 Answers
  • Posted on Nov 25, 2008
SOURCE: instruction manual
Here are the instructions: DRAGON HM3
If the model is different , download from:
Select your product, insert model and download instructions here
Anonymous
  • 89 Answers
  • Posted on Nov 01, 2009
SOURCE: Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Anonymous
  • Posted on Oct 14, 2010
SOURCE: delonghi dragon oil filled heater
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Anonymous
  • 4736 Answers
  • Posted on Apr 19, 2011
SOURCE: I would like to obtain a instruction manual for
If you live in the US, Call Delonghi Customer Support @ 800-322-3848.
If you live in Canada call 888-335-6644
If you love in Mexico call 800-711-8805
That should help you, Peter.
Delonghi dragon 3 not working beep
The appliance beep's to indicate a malfunction. My manual say's to contact the De'Longhi customer service.
I would like to obtain a instruction manual for the DeLonghi Dragon 2 oil filled radiator. Do you have an address, phone number or place I can contact. Thank you,\r\nPeter Knight
4helpful
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
5helpful
2answers
Dragon wont turn on, have checked the fuse
We had the same problem. The on/off switch is likely to be broken inside. We tried to fix it but its likely the pcb is damaged. If you contact Delonghi direct they will help resolve. They sent us a new heater (10yr guarantee)!
2helpful
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
15helpful
2answers
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
