Question about HP LaserJet 2605DTN Color Printer
HP Color LaserJet 2605dtn won't print magenta at all.
All the other colors print just fine, but magenta won't work at all. replaced the cartridge and nothing happened.
  • somadude Feb 04, 2009
    I have the same exact problem. It seems like this is a design flaw in the 2600 series where the magenta part of the laser assembly gets dirty easily, and doesn't let enough light get through.
    There are instructions on how to fix this, but it's pretty complex for the typical user.
    Here's some info I got off the interwebs...
    Fading Red Tones on Color LaserJet 2600s
    HP Color LaserJets 2600n, 1600, and 2605 share the same basic Canon engine design. One aspect of the design brings the common problem of scanner optic degeneration due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow.
    Fading reds, like death and taxes, are to be expected sooner or later—sooner in dirty environments. HP has not documented a cure. Its service literature does not cover removing, let alone cleaning, the laser/scanner assembly. Nor does HP sell replacement units.
    The best test for faded colors comes from the "config report," printed from the control panel menus: Press Select (check mark key) twice, then the right arrow key twice, then Select. Blocks of color along right and left sides of the config report show fading if present.
    The following procedure leads you through removing and cleaning the laser/scanner assembly, along with an explanation of why reds suffer first, followed by yellow, cyan, and finally black.
I just encountered this problem with my 2600n purchased in June2008. I'm not very mechanical and had no difficulty following the instructions providing in the link above (Feb 04, 2009) and solving the problem on my own. I have printed well over 10,000 pages on this printer and it ran like a dream until the dusty mirrors interfered with color quality. Now its back to usual top-notch quality and I'm thrilled. Thanks for the posting of service instructions for a quick DIY and saving me the expense of servicing, recycling and/or purchasing a new unit.
Posted on Nov 03, 2009
Common Problem!  You can fix this by taking machine apart and cleaning the mirrors and lasers.  Remove the toner cartridges and look inside--notice that the magenta cartridge sits right next to the fan.  Its a problem just waiting to happen.
Posted on Jan 02, 2009
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
Aug 09, 2011 | HP Color LaserJet 2600n Printer
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 ( if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
First of all clean the contacts in the printer for the magenta cartridge, if there is no improvement replace the magenta cartridge, if that doesn't work come back to me
Jun 12, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2605DTN Color Printer Logo
1,666 people viewed this question
Ben Johnson
