Question about Xerox DocuColor 12 Color Copier
Error 9-363 Xerox code
Hi, Thank you very much for your answer. It was very helpful. Do you know anything about a 9-363 error code?
If I get error 9-363 is this a fuse problem. If so, the fuse do not look blown. One board has 4 fuses and another board has 5 fuses from the back. How do I know which fuse to check. Is it the rotary pwb? If so, which board is it and do I change all the fuses? Is this a slow burning fuse? Even not blown still needs to be replaced? Is this correct? Thank you for your help.
  • 62 Answers
Yes Its on the rotary pwb. Its behind the IOT pwb. Basically at the top left hand corner as you look at the rear of the machine. I think it is a 3 amp slow blow but cant quite remember. Definately slow blow though. Sometimes if you meter them they can read ok but as soon as a load is passed through them the fuse cant hold the charge and fails. It is the 2 fuses that are harder to get at, may as well change all 3 whilst your there. The rating for the fuse is written on them. Worst case is the developer motor has seized, taking it off an putting it back on again usually remedies this, but its a bit more awkward to get to. Fuses first
Posted on Dec 31, 2008
How to resolve error 14?
Hi Japhet,
It seems obvious to me that you should search online to answer your own question. Search "error code xxxx Xerox" and see what you get.
Jul 23, 2015 | Xerox Phaser 6120N Printer
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
IR400 xerox machine shows main swicth on off & E243 code error
What is the error code that is displayed? If it turns right off, hold the main power switch till the display screen display's the error code. Write it down and let the forum know what it is, it will help with a answer.
Sep 06, 2013 | Canon imageRUNNER 400S Copier
Hi there, Im getting an error code: 07,010.43:48669 on my printer, can you maybe help? Error occurs @ 5% warm up. Id also like to know if you perhaps have the schematics and a service manual? Thank...
The most common thing that causes this issue is the drum maintanance cam and or DM pivot plate. I would check the cam like it discribes and also make sure the pivot plate isnt cracked. But really the service not gives you a list of what all needs to be check.
The Xerox website says to take it in to a service center: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=121,E=0000000002388339860,K=7746,Sxi=4,Case=obj(21655)
And here is a link to the documentation http://www.support.xerox.com/support/phaser-8400/documentation/enus.html
Nov 17, 2010 | Xerox Phaser 8400 Laser Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox DocuColor 12 Color Copier Logo
527 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
