Question about HP DeskJet 3650 InkJet Printer
Printer jams when using Kodak Picture Paper
Is there a setting on the HP Deskjet 3650 for thicker paper? It continues to jam when I use any kind of glossy medium weight paper to print pictures. Very frustrating!
  • Anonymous Mar 30, 2014
    pulls paper in does not print
    Problem Solver:
  • 7 Answers
Check the HP support pages, but as HP inkjets turn the paper over internally it means their weight limit is likely lower than others. Also check you have loaded paper face down so it is glossy side UP as it turns over for printing. Their site quotes a max weight of 200GSM for thick stock http://h10025.www1.hp.com/ewfrf/wc/docum... Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
Posted on Aug 04, 2007
Paper will not pull through. I have paper in printer and get no paper message
Do you have a jam? You can open your printer from the back, and pull your jam out. Hope this helped
Jun 04, 2011 | HP DeskJet 3650 InkJet Printer
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
Aug 09, 2010 | HP DeskJet 3650 InkJet Printer
I am unable to print because of a "paper jam". I have removed the paper from the printer, unhooked the printer from the computer, etc. and continue to get this message. Can you help?
A "paper jam" means that there is some paper or a piece of paper somewhere inside the printer, in the paper rollers. Turn the printer OFF. Open the printer and carefully look for a piece of paper or a paper page half-folded inside. SLOWLY pull the paper out. Replace the cover and turn on again.
Apr 01, 2010 | HP DeskJet 3650 InkJet Printer
Paper jam error but without any paper jammed. btw printer is hp 3650
Do Page Alignment & it will fix you problem.
Check Is there any peace of paper remained in printer. Clean Page Loader.
Thanks.
Oct 14, 2009 | HP DeskJet 3650 InkJet Printer
Printer will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet 3650 InkJet Printer
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Paper jam?
There is most likely some paper jammed inside the printer. You just have to carefully look everywhere you can see to see if there might be a little bit of paper stuck somewhere.
Often blowing gently (and dryly) into the printer will dislodge whatever is stuck.
Jan 13, 2008 | HP DeskJet 3650 InkJet Printer
Paper jam
a jam could be confused as a slow-turning roller to the machine. try to clean your rollers with alcohol and then lubricate the roller axle bushings with 30W oil.
Jun 08, 2007 | HP DeskJet 3650 InkJet Printer
HP DeskJet 3650 InkJet Printer Logo
194 people viewed this question
Clive
Clive
