Question about Pioneer VSX-D509S Receiver
The negative battery connection came loose from the circuit board
The remote control has space for TWO AA batteries. The cells are placed in ''series''. The negative wire (conical shaped spring) that leads to the circuit board has come loose and does not complete the circuit any longer. What is best way to resolder to a circuit board?
    Genius:
  • 1,175 Answers
Radio shack sells a cheap entry level soldering kit
and there are videos on line on how-to solder..check you tube
Posted on Feb 08, 2009
My hunter ceiling fan works by remote . My remote fell And the batteries fell out, now my ceiling fan won't turn on the lights or the fan. It won't even work if I pull on the chains
I always look for the simplest answer first.
This MAY be the problem: you reinserted one or more of the batteries with the wrong orientation. Typically, they will connect in series to produce a higher voltage than a single battery by itself.
For example, an AA battery puts out about 1.5 Volts, and two AA's in series would produce about 3 Volts, with the positive of one battery connecting to the negative end of the other; the negative of the first and the positive of the second connect to the remote's terminals. The connection between the two batteries is usually in the battery holder in the remote, and the batteries will be physically oriented in opposite directions. For example:batts-g3g4rd04a0x5u31qpoveqzom-1-0.gif
Of course, something inside the remote may have broken instead, but double-check the battery connections first.
Nov 14, 2017 | Hunter (25417) Ceiling Fan
My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Jan 07, 2017 | Toshiba Televison & Video
How do i disassemble the DirecTV RC71 Remote?
Check for more screw(s) behind the label/sticker. Also, you may need to have a flat edge screwdriver or knife to prise open the remote.
Sep 24, 2014 | Directv Televison & Video
IPod classic stopped working. No response at all. It was working fine one day and the next day, nothing.
batterys are loose with intermittent power to thermostat circuit board place a tightly folded aluminum foil to about a 1/4inch square and place it between or at either end of the AA batteries. This tightens the connection and makes for a better contact.
Oct 08, 2012 | Apple iPod classic 80 GB Digital player -...
Well the remote was dropped and came open,the battery flew out.i replaced it but the truck lockes won't respond.
Do any of the other functions work? Since the battery came out, you may need to take it to a dealer and have the remote re-keyed to your specific car. If other functions do work, the circuit board in the remote might have been cracked across the traces to that particular button.
Apr 30, 2011 | Nissan Armada Cars & Trucks
Changing rechargeable battries 45-40
Metz 45-40 consist of 6 nos of NiCd - AA size batteries connected in series. These battery packs can be rechanged by resoldering new set of AA size rechargable Nicd battries. Care should be taken not to short circuit the cells when disassembling and assembling the cells. Keep a note (sketch) of the connections of the cells, specially the longer connecting metal strip and the polarities of cells. re-solder the new set of AA size NiCd Batteries. If the old wires were corroded, use new wires' If the connecting terminals also corroded' clean it. If it is severely corroded, get it plated prior to fixing for better performance.. There is an charging indicating lamp which also control the charging current of the batteries. check its connections and solder it if required. I wish you got the answer for your problem.
H.D. Shirantha.
Sep 07, 2010 | Metz 45 CL-1 Flash
I have a Sony icf 2010. No sound, but white noise.
AA batteries need replacing or the contacts are corroded and one more, the PC board is connected to the AA negative post by a wire that touches the pad on the PC board. Sometimes it will lose contact because of oxidation or corrosion, to fix this a wire soldered is best but just repositioning the wire will make the cure. Requires removal of the circuit boards.
Jan 20, 2010 | Sony ICF-2010 AM/FM/SW Radio
Remote keyless intermittent function
I had the same problem. If your car is still under warranty, simply go to the dealer and have the keyless entry remotes replaced. If your car is not under warranty and you do not want to fork over the hefty fee for new remotes, you should be able to repair them yourself.
If you open your keyless remotes, you will likely find that the contacts which hold the battery in place have come unsoldered. Basically, the problem lies in the fact that Daimler/Chrysler used a cold soldering method when adhering the battery contact to the circuit board in some of these remotes. Under normal wear, these cold soldered contacts will eventually bust loose.
In order to repair the remote(s), you will need a soldering iron and solder.
1)Remove the screw from the back of the remote. Pry apart the two halves of the remote using a dime or penny.
2)Remove the circuit board, placing it battery side up. Remove the battery.
3)Carefully place the battery holders contact pins back into their respective holes.
4)Take care to put a small amount of solder on each of the loose contact pins. Put a small bead in both the back and front of each contact pin.
5)Replace the battery and put the circuit board back into the remote. Test to make sure the remote is functioning properly, then snap the back of the remote on and replace the screw.
Don't thank me, credit for how to repair this issue goes to 'Sodapop' from custommagnums.com.
May 01, 2009 | 2005 Dodge Magnum
Jeep hard to start then wont idle
Batteries are only good for about 5 years, any older and you risk a dead one in the middle of winter. First make sure your battery cables are tight and you do not have any corrosion (white residue) on them. Next, you should run to autozone and have a free check of your battery and alternator. If you are electronically inclined you can do this procedure to check your battery on your own.
Hook multimeter to battery, it should ready >12 VDC--tests battery condition
Crank car, it should read >13.5--tests alternator charging capability
Turn car off, wearing rubber gloves/eye protection undo battery vent caps (should be 2 of them, depending on the battery). Have baking soda and clean water handy if you get acid on you. Just rub with baking soda and rinse with water.
With vent caps off, you will see 6 holes on the top of the battery. Each hole represents a series circuit, much like putting 2 AA batteries in a remote control to make the voltage 3 volts. Each cell is a multiple 2 volts. Place negative lead of multimeter on negative of battery, Next place positive lead inside battery cell until you are touching the acid. Going in sequence, each cell should give you a reading of 2,4,6,8,10,12 volts. If one cell doesn't give you a multiple of 2 volts, it is a "dead" cell and the battery will need to be replaced.
Also be advised that the alternator is not designed to charge a dead battery, only keep a good battery charged. If you keep charging your bad battery, you alternator will be the next to go. This is why they seem to go in pairs.
Oct 21, 2008 | 1998 Jeep Cherokee
Pioneer VSX-D509S Receiver Logo
236 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
