Question about Xerox DocuColor 12 Color Copier
Error 9-363 Xerox
Hi Tryit, If I get error 9-363 is this a fuse problem. If so, the fuse do not look blown. One board has 4 fuses and another board has 5 fuses from the back. How do I know which fuse to check. Is it the rotary pwb? If so, which board is it? Is this a slow burning fuse? Even not blown still needs to be replaced? Is this correct? Thank you for your help.
  • 2 more comments
  • howsimple Jan 02, 2009
    Yes, a lot of black has ran through the machine.
  • howsimple Jan 21, 2009
    Thank you. I changed the developer and it worked.
  • howsimple Jan 23, 2009
    I am new, so can you please clarify. Do you mean too much developer in
    the housing? Or are you talking about the toner cartridge? If I INIT
    the IOT, where or how do I back up it up? When you INIT the IOT,
    doesn't it bring everything back to default, so why would you want to
    back it up? What does IOT stand for? If I clear all the NVM, doesn't it bring everything back to
    default? How will I load the IOT software? Don't I need a laptop and
    connect it to the slot inside the right panel? Thank you for your help.
  • paghorashy May 11, 2010
    Was the fault declared after a long run of Black Only prints or Copies.
    Problem Solver:
  • 8 Answers
Well I dont know how extensive you want to get but is what is happened is the Black developer housing has gotten to much toner in it and it is packed in there. The solution to the issue is to replace the developer material. with new. It may not be nessasary to replace the housing but that may also need to be replaced.
Posted on Jan 04, 2009
  • paghorashy Jan 23, 2009
    The problem may be still too much toner in the black housing. Are you still running high black content? you may need to change the dev housing with one with a larger waste despence opening or you may have IOT software corruption and my need to INIT the IOT but you must make sure you have backed up or have the Critical NVM backed up. or you may have to load IOT software to get this solved. The fuse issue is not what causing this issue given the information thus far
Error message CE displaying. Machine will not run.
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Oct 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Hi my worksatation xerox 15i flashes OVER HEAT on the lcd screen and doesnt work after that!
Need to replace the fuser. Look up a business called The Parts Drop and give them a call.
Jul 04, 2010 | Xerox WorkCentre M15i Laser Printer
Receive H 4 error code on zerox 1255 copier-nothing happens, the machine won't turn on-tried switching power of for 5 seconds nothing happened. Made sure the machine was pluged in a receptacle by its self,...
A H4 code is a problem with the fuser unit. That xerox is a Sharp copier. You may have a blown thermister or thermal fuse or a fusing lamp. You may need to repair the problem before you can clear it. I believe the code to reset it is in service mode SM 16
Mar 12, 2010 | Office Equipment & Supplies
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Error 9-363 Xerox code
Yes Its on the rotary pwb. Its behind the IOT pwb. Basically at the top left hand corner as you look at the rear of the machine. I think it is a 3 amp slow blow but cant quite remember. Definately slow blow though. Sometimes if you meter them they can read ok but as soon as a load is passed through them the fuse cant hold the charge and fails. It is the 2 fuses that are harder to get at, may as well change all 3 whilst your there. The rating for the fuse is written on them. Worst case is the developer motor has seized, taking it off an putting it back on again usually remedies this, but its a bit more awkward to get to. Fuses first
Dec 31, 2008 | Xerox DocuColor 12 Color Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Error code 9-354
open back side door
and check fuses u get 2 fuses on board
check that fuses & replace
Dec 05, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
967 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
