SOURCE: peugeot 206 glowplugs
If your not good at mechanicing I suggest you take the car to someone that is experenced.
The reason I say this that we have loads of cars into the workshop with glowpugs broken in the head of the engine with the result of us having to remove the cylinder head.
What happens is that the tip of the glowplug breaks in the head when being removed if it is not done properly.
There is a way that we have found that they can be removed easily without breaking them.
Firsty run the car engine until warm, then we pour a little Diesel fuel onto each plug & let them sit for 15mins or so.
Then we remove them with a deep socket 1/4" drive so we don't put to much pressure on them.
they should screw out easily but we turn them out 1 whole turn then back a 1/4 add a little more diesel ( thimble full) & gently screw them out.
If they start to get really tight screw in again a little then screw out again.
The nuts that hold on the wires just need to be nipped up with a small 8mm spanner, but do not over tighten.
SOURCE: need instructions on how to fit auto adjusting peugeot 206
cant honestly say i have fitted one on this model,but is it full auto or is their an adjuster on the back of the clutch pedal.??? look first.Ford escort one is a bit of a pig but easy when you have the knack same as a golf easy when you know how .Now golf cable comes with two plastic ties that hold auto adjuster together and you dont relaese them till the cable is fitted.Can you describe the set up then i might be able to help some more.American web site so a lot of models not listed here and the lingo take a bit as well ,i mean whos ever heard of pigs tails or fire wires.Well what else can you expect when they are not taught the queens english and dont drink tea, just waste it by throwing it in the sea.
SOURCE: Random Overheating Problem on Peugeot 206
It sounds like your thermostat has gone bad and sticking close, Replace the Thermostat and Antifreeze. When replacing the thermostat, buy a fail safe thermostat so you will not have a overheating problem when the thermostat fails. Good luck and hope this helps. Keep me posted, be glad to help.
SOURCE: peugeot 206 cc fan belt change
hi ive a peugeot 206cc 02 reg, the STOP light keeps flashing ive checked the normal oil and water but alls ok so whats the problem still runs fine and temp stays where it should??? any tips??
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
Car Stalls and idles low
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
I have cleaned the throttle body, which was filthy inside and run concentrated redex through fuel system
