Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
FROZEN ZUNE 30G SCREEN - Microsoft ZUNE JS8BRPBDLUG MP3 Player
  • 6 more comments
  • Anonymous Dec 31, 2008
    There are all frozen! MS is working on it.....
  • mmartinez2 Dec 31, 2008
    two units with same problem, frozen with zune logo on the screen
    They are all like this currently...Sucks for us to support Microsoft.
    its
  • Scudhunter19 Dec 31, 2008
    its frozen on the zune screen
  • Anonymous Jan 01, 2009
    Yeah mine too.... maybe it is the update I put on not long ago!!!
  • ceq617 Jan 01, 2009
    My son's 30GB just started this same thing.
    I was thinking of the update as well.
  • FiggyPop Jan 02, 2009
    My Zune is frozen on the Zune screen.
  • 916 Answers
Press and hold Back button plus up on the pad.
Posted on Dec 31, 2008
Http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
go to step 4 only remove clip for battery wait ten seconds. It worked for me!
this solution is from darksonday
Posted on Jan 01, 2009
Try holding up on the zune pad and the back arrow
  • Bardockslash Jan 01, 2009
    Special Combinations
    Turn off: back button and down button
    Reset: back button and up button
    sleep: Play/Pause Button
    Reformat:Reset(back button and up button) And while in reset press back button,center button, and play/pause
Internal clock problem / leap yr. see zune posting for fix - will resolve jan 1 2009 -
  • 4 Answers
There's a fix:
"Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it if you think you'll screw it or something. :)"
Not pretty, but it might help those of you who have this problem.
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune reset
Hi I can help you this is how. BUY A 4G ZUNE!!!!! cause your 30g zune is broken or something, or reset everything and instal it again
Jan 13, 2009 | Microsoft Zune JS8-00001 Digital Media...
Upon startup my zune 30g locks up .
theres a lock thing on the top of the zune switch it so you dont see the red mark it should unlock
Same thing to me this morning
nothing is working at the moment .. this only happened to the 30g even if the battery dies it will stil be frozen..
http://forums.zune.net/403986/ShowPost.aspx
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
30g Zune Frooze for no reason.
microsoft is aware and looking for a solution. this happened to every 30g owner. here is the website for the right forum... http://forums.zune.net/403986/ShowPost.aspx check the zune site for updates
Zune 30GB froze
pull the case apart, unplug the battery pack for about 30 seconds, then put it all back together. it's not near as hard as it looks.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
My zune sucks
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Oct 23, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
After charging it froze up!
I have the same problem, it is completely frozen and will not turn on or off even after I charge it. It appears to be completley frozem, help!
Aug 29, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
156 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
