Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis....how do I get the timer off the console ??
I have a maytag atlantis that will not cycle or do anythintg. I have checked the plug and plug in..all breakers are fine. Looking on the internet seems like it might be the timer. I have the console apart and the wires disconnected from the timer. I can't figure out how to get the timer off the machine without breaking it.
  • 640 Answers
Easy lau...ok since you have the console of ,,just go to the timer knob you see that round piece in center thats just a cap take screwdriver and pop it off gentle...noe remove that clip,,theres a spring under thre dont let it bounce away ,,easy,,now remove the dail just pull it of with your hand,,,ok see the 2 scerws holding the timer,,,orayyy,,if you need help im onthejob
Posted on Jan 03, 2009
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Aug 31, 2009 | Maytag Atlantis MAV7260B Top Load Washer
MY MAYTAG ATLANTIS WASHER KEEPS WASHING RIGHT THROUGH THE RINSE AND SPIN CYCLES. I HAVE TO MANUALLY TURN IT TO GET IT TO START DOING THE RIGHT THING.
Hi, your timer motor not working,(burnt) or could be mechanical fault in timer, but first replace timer motor, check for timer motor, give appliances store model & serial no. for washer, and let me know when you get it, i will guide you, to install it, yes you can, it's not that complicated. don't forget asked for timer motor. good luck.
Aug 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
