Question about Whirlpool LER5636P Electric Dryer
I am trying to locate the correct screw size to attach the electrical cord to my Kenmore dryer since my hubby lost the correct ones.
    Sergeant:
    Champion:
  • 262 Answers
I think they are #20 fine thread
Posted on Jan 10, 2009
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Where is the electrical cord located on a Maytag 3000 dryer?
U NEED TO BUY THE ELECTRIC CORD , ON THE BACK HAVE A COVER AND U CAN SEE 3 SCREWS FOR ATTACH THE 3 WIRES .OF THE CORD
Nov 11, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Need to hook up new plug
Red on one side of terminal block, white in middle, red on other side. The green is attached to outside using screw to to top left of terminal block compartment on outside of cabinet. Hope this helps!
May 18, 2009 | Kenmore 62602 Electric Dryer
Change out 3 cord plug with a 4 cord plug
very easy just put the white to the middle the black to the left the red to the right and the green can attach to the cabinet with any screw close by
May 11, 2009 | Dryers
Screw Size to install electrical cord
they should be what is called a 10x32 screw. you should be able to get these from any hardware store. not at home depot or lowes, but like an ace hardware. they will know what you are talking about.
i would guess that someone lost your original screws. if not then you might be having problems because the screws got stripped out when trying to change the cord or hook up a new one. if that happend, then you will need to replace the nuts also. get them at the hardware store too.
it may not be easy but you will save alot of money if you can do this yourself.
Dec 31, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer swap pwr cord from a 4 to a 3 prong
Remove the cover plate just above where the cord goes in (1/4" screw) Loosen all 4 screws (3 brass ones and a green one) and see if the connectors will come off. (this is for a "fork" type connector) if the connectors won't come off, you have a "loop type connector in which case you will need to remove all the screws completely. BE CAREFUL! If you drop one inside the machine, you will have to dis-assemble it. Now, re-install/ tighten down the green screw. (If the green screw wasn't used, the unit wasn't installed correctly at the time of install). Loosen the screws on the clamp where the power cord comes into the washer. (again, they may be missing do to improper install). Now, install you three prong cord in reverse. (The cords are flat so you can't mix the wires up on most models of cords) Make sure to put the clamp (strain relife) on that was supplied with your new cord.
Jul 06, 2008 | Kenmore 62722 Electric Dryer
Kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Jun 07, 2007 | Kenmore 62722 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
