Question about Casio Exilim EX-Z750 Digital Camera
My camera keeps turning off when I turn it on, and the battery is fully charged. Right before it turns off it says "alert" in red letters.. help!
  • fess123 Mar 04, 2009
    My Kodak easyShare cw330 keeps going on and off and wont stop. It turns on,the lense comes our then it turns itself off and then back on again over and over. I tried different batteries and still have the same problem.
  • 33 Answers
Your batteries could be bad. If not then you could send it in to for an estimate. It would most likely be a power board
Posted on Dec 31, 2008
HD camera.flip style
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged.
While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
Jun 04, 2013 | Cameras
Canon DSLR will not turn on
Hi there,There are a few things we can try/check here!
1.Turn the camera OFF. Remove the battery and clean the contacts (shiney metal strips) on the battery.2. Remove the lens and clean the lens contacts.3. If you have a body cap, put it on the camera (no lens, just to keep dust out right now).4. Reinstall the fully charged battery and turn on the camera.
It should start up. If so, turn it back off and reinstall the lens.
Also, be sure to check all the doors/hinges on the body. These are found on the battery and the memory card. They have electrical contacts on them that need be to be fully closed.
If possible, try a different battery (a friends, or take it to your friendly neighbourhood camera shop).
Hope it turns back on!
May 07, 2012 | Canon EOS Digital Rebel XTI Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
May 28, 2009 | Kodak EasyShare Z700 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Wont hold Charge
When you charge the battery what does it do? Does the red light flash or stay solid? If it stays solid while it's charging then you should be ok. Casio doesn't recommend using any other brand of battery with their cameras because we don't know how they will react. I would say try a regular Casio battery and see if that solves your problems. I know that means a little more money but a lot of times I have seen that solve the problem right away.
Apr 09, 2008 | Casio Exilim EX-Z55 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
169 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
