Question about Maytag Atlantis MAV6000 Top Load Washer
How do you get the timer off a maytag atlantis toploader?
  • 640 Answers
First unplug unit,,remove the three top screws across backof console..now on timer knob remove the outer most cap or the center cap..remove the clip,,carefulf now theres a spring behind knob dont let it fly ,,remove dail...good,,,noew go back to console and flip it down top towaeds you bottom away,,jiggle just a touch now your in,,remove 2 timer screws from front ,,reverse to to put together...onthejob
Posted on Jan 03, 2009
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Hi i need the part number for a maytag atlantis dryer timer
part number for timer is AP4043083 , if you also need the timer clutch that number is AP4042974 both thru appliancepartspros for about $85.00 each
Mar 05, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis top-load washer has a big lint problem
My dryer is making a noice and will not start how do I open it to see if the belt is broke
Jan 17, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
152 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
