Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Facia panel keeps breaking/bleach ruins clother/water level too low and doesn't clean well
My facia panel keeps breaking. When I put bleach in the bleach container it gets bleach spots on my clothes, ruining them. There isn't enough water to get the clothes clean. The washer vibrates way to much.
  • Anonymous Mar 29, 2014
    Where did the water come from
  • 183 Answers
Do not use bleach, if you do you will get a bleaching effect,the new machines use less water, do not volume overload machine. mix the load to prevent uneven out of balance spin and check feet are level. Ragrds Advisor
Posted on Aug 23, 2007
Is there a way to figure how many linear ft. a 1,400 square ft. home is that only has 4 main outside walls? So pretty much a square home. Needing to put new facia up and trying to get an estimate.
no
linear measurement is a length measurement and you have given an area measurement
facia timber comes in a set width and thickness so all you have to do is measure around where the facia is to go and that length will be the linear measurement of the facia board
so you get that measurement and go to a timber yard and say you want so many feet of facia board
Dec 14, 2017 | Linear Office Equipment & Supplies
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
How do I replace a damaged speaker
Place clean thicky cloth on level surface, open lid, at rear. Facia gentle apply lifting pressure to rear facia either end, held in by small plastic lugs, so be careful when applying lift, should pop out exposing speakers. Rest common sense and apply no undue pressure.
Aug 10, 2014 | Toshiba Satellite A105-S4284 Notebook
Have just moved into house with this oven. Need a copy of the front of oven face. not sure how to work it without numbers and words to tell me what switch does what. the writing has been erased from front...
contact maker and order a new FACIA PANEL, no known maker/supplier of transfers. OR,,, get the manual and by reffering to the user instruction book there MAY be a layout diagram of the controls on the Facia and you can put stick on labels to guide you until the new Facia arrives
Sep 15, 2011 | Ovens
How do you remove the front facia door of a Teknik integral dishwasher
I have just replaced the facia on mine. It is a TKD795/4 so I would imagine yours would be very similar. Around the inside of the door are 10 starhead screws; 4 along the top and 3 down each side. On mine it is the 2 end screws along the top and the 2 middle screws down the sides that hold the facia on. It is best to remove one screw at a time to establish which ones hold the facia on and which hold the door together. The short screws hold the door together and should be replaced and left in place. It is the longer screws that hold the facia on; these only need to be undone enough to release the facia panel. Once you have undone the relevant screws, the facia will lift up enabling you to release the 2 clips at the bottom. Replacement is reverse of removal. Hope this helps.
Feb 26, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
The part that controls the water level is broke
You didnt give a model number, but I will assume it is a top loader with a level selector knob. Is the stem still visible, or did everything break off? You can remove the facia panel with the phillips head screws on each end, and by removing the program selector knobs by pulling straight out. The level selector is fairly simple to replace. there should be two wires and a clear rubber tube. get your new part from an appliance part store ( less than 30 dollars). unplug the machine, and transfer the wires to the new part one at a time keeping them in exactly the same place. undo the hose clamp ( if present, sometimes just held on by pressure fit) and connect the pressure tube to the new level switch. re assemble the facia panel, plug the machine back in, and give it a test.
Nov 20, 2010 | Maytag Washing Machines
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Break lighe comes on when I start and stays on for
If what you mean by break light is the warning on the dash facia then it could either be fluid level or the button on the park lever is sticking.
Dec 03, 2009 | 2004 Nissan 350Z
How to change the 2001 hyundai santa fe fog lights
you will need to completely remove the front facia (bumper to get access to the fog lamp assemblies as they are bolted in from behind. No big deal. There are a few screws along the top of the facia under the hood along with some plastic push pins ( you may want some extra ones on hand before starting this) There is a screw where the facia meets the front quarter panels in the wheel wells and there are about 8 push pins along the bottom of the facia that need to come out. Then lift out. No sweat right! For real though it isnt. Just a side note, while you have the facia off you now have easy access to the windshield washer pump motor. This is a perfect time to remove the pump, clean the screens and flush your resivor tank out. Getting clogged pumps seem to be common place on hyundai's vehicles. Please let me know if this helps.
Oct 11, 2009 | 2001 Hyundai Santa Fe
Facia panel removal to change radio
YOUTUBE HAS GOOD VIDEO ON FORD CAR
RADIO REMOVAL.
Apr 13, 2009 | 2004 Ford Fusion
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
199 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
