Question about Car Audio & Video
I have an alpine 9886 and I dont have volume out of the 4 speakers but my subs are working.
  • garbo1210 Jan 14, 2009
    I hooked up the remote wire to the amp and shazam it worked.
  • John Larsen May 11, 2010
    are you running a highs amp also??
  • 77 Answers
If you have the deck keys try pulling the deck out and check the rca's or speaker leads to ensure all is connected properly. if not then solve. if so then it leads into more trouble shooting. best thing about car audio is it is typically a process of elimination. start with power and ground and then check signal wires and connections.
Posted on Feb 19, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I can no longer adjust my subwoofer level from my head unit. I used to be able to in my other car but since I put it in my new car I can no longer adjust it? I have the alpine cda-9886.
make sure that before the sub woofer is hooked into the stereo that the settings for the sub are blank that way there is no previous setting once you have hooked up the sub and amp.
Feb 04, 2011 | Car Audio & Video
My alpine cda-9886 restarts when i turn it up to about 22. i have no idea how loud it goes. i bought this refurbished from overstock.com about 3 years ago. its becoming annoying now.
the unit may see a short in one of the speakers that is causing the transistor to protect itself by shutting down. Try changing the balance and fade settings to listen to one speaker at a time. If any speaker isn't working, that would be the one causing the problem. If you disconnect the speaker and the problem resolves, the speaker is bad. If the problem doesn't resolve, the problem is in the wiring or an internal short in the head unit. In fact, you may want to start at the head unit and disconnect the bad channel from the head unit. That way you can discover right away if the short is internal. You can even disconnect all the speakers at the head unit and turn up the volume. If it cuts out, it has to be an internal short. If you're good with electronics, you may be able to find the short inside. OK?
Dec 07, 2010 | Alpine CDA-9886 Car CD/ MP3 Player
What speakers should i get for the cda 9886 i have a 2000 pontiac grand prix gtp 2dr coupe
The world is your oyster mate, you can have what ever speakers you want in other words, With the Alpine you probably have preouts as well, preouts being red and white adapters that plug into the back of your unit to enable you to extend your system to an amplifier and subs as well as the four standard speakers
Feb 03, 2010 | Alpine CDA-9884 Car CD/ MP3 Player
I just hooked up a a cda 9886 in my car and know my subs dont work do you know what the problem could be
Your subwoofer is probably off. You have to put it on. I think you have to push the button all the way on the right that says imprint or sound setup and then dial the rotary to subwoofer and there is an adjustment or a level. You choose the one that is not level and select it then on or off. It is easy once you figure it out.
Jan 03, 2010 | Alpine CDA-9886 Car CD/ MP3 Player
My alpine works but it puts out no sound
Hold down the (F) button for several seconds. Release button and select (General) by turning volume knob and press (enter). Now select (Power IC) by turning volume knob and press (enter). Now turn knob and select (on) then press (enter). Hold (escape) button for several seconds.
Feb 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
I just hooked up my alpine 9886 .I have volume on the subs but none on the other 4
You have turned off your "POWER IC" option. This truns off the internal amplifier and only attenuates the output the the RCA terminals. That's why only your sub output works.
Dec 31, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
