Question about Microsoft Zune JS8-00001 Digital Media Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and middle button which also hasn't work. I let the battery run out and when I charged it, it was still frozen on the same screen. Please help! Thanks!
  • 4 more comments
  • Anonymous Dec 31, 2008
    I have the same problem. Has anyone found a solution yet?
  • aaah Dec 31, 2008
    I have the exact problem.
  • fastkide Dec 31, 2008
    how do u fix this i just baught mine 2 days ago and it already froze what do i do?:(
    Yea, this sucks
  • edwin plumey Dec 31, 2008
    I have the same problem and i remove the battery and it still froze.
  • Ringochan Jan 01, 2009
    I have the same problem , OMG I am gonna kill my self
    Problem Solver:
  • 6 Answers
I removed my battery for 30 seconds and now it works so far. Here is the link for instructions and do not go past step 4. http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Posted on Dec 31, 2008
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Frozen screen
Got it working again. Disassemble and disconnect the batery for about 10 seconds. This worked to resent mine and it's working again. Not sure if it's permanent, but working for now.
Disassembly instructions:
Zune frozen with zune logo on screen
There is a problem with these known as the Zune 30's y2k9 bug. If you call they will fix the problem for you for free. Call 1-877-438-9863 for zune technical support.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
30GB Zune Froze
all of the zunes 30gb in the world went dead last night go to zune support.com and request a repair they will be helping you soon .
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
30 gig Zune is froze up
Mine is locked up also. I tried the back and up keys simultaneously and nothing happened. The screen is stuck on the zune logo with the white bar on the bottom.
Microsoft Zune JS8-00001 Digital Media Player Logo
53 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
